Bounds for the Coupling Time in Queueing Networks Perfect Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Jantien G. Dopper
  • Fonction : Auteur
  • PersonId : 833440
Bruno Gaujal
Jean-Marc Vincent
In this paper, the duration of perfect simulations for Markovian finite capacity queuing networks is studied. This corresponds to hitting time (or coupling time) problems in a Markov chain over the Cartesian product of the state space of each queue. We establish an analytical formula for the expected simulation time in the one queue case and we provide simple bounds for acyclic networks of queues with losses. These bounds correspond to sums on the coupling time for each queue and are either almost linear in the queue capacities under light or heavy traffic assumptions or quadratic, when service and arrival rates are similar.
Autre [cs.OH]
RR-5828.pdf (337.86 Ko) Télécharger le fichier
inria-00070197 , version 1 (19-05-2006)
  • HAL Id : inria-00070197 , version 1
Jantien G. Dopper, Bruno Gaujal, Jean-Marc Vincent. Bounds for the Coupling Time in Queueing Networks Perfect Simulation. [Research Report] RR-5828, INRIA. 2006, pp.25. ⟨inria-00070197⟩
172 Consultations
94 Téléchargements
