Maximum Likelihood Estimation of Discretely Sampled Diffusions: A Closed-form Approximation Approach, Econometrica, vol.70, issue.1, pp.223-262, 2002. ,
DOI : 10.1111/1468-0262.00274
The Law of the Euler Scheme for Stochastic Differential Equations: II. Convergence Rate of the Density, Monte Carlo Methods and Applications, vol.2, issue.2, 1995. ,
DOI : 10.1515/mcma.1996.2.2.93
URL : https://hal.archives-ouvertes.fr/inria-00074016
The Law of the Euler Scheme for Stochastic Differential Equations: II. Convergence Rate of the Density, Monte Carlo Methods and Applications, vol.2, issue.2, pp.93-128, 1996. ,
MCMC for nonlinear hierarchical models, pp.339-358, 1996. ,
Retrospective exact simulation of diffusion sample paths with applications, Bernoulli, vol.12, issue.6, 2005. ,
DOI : 10.3150/bj/1165269151
Martingale Estimation Functions for Discretely Observed Diffusion Processes, Bernoulli, vol.1, issue.1/2, pp.17-39, 1995. ,
DOI : 10.2307/3318679
Bayes and empirical Bayes methods for data analysis, of Monographs on Statistics and Applied Probability, 2000. ,
The SEM algorithm: a probabilistic teacher algorithm derived from the EM algorithm for the mixture problem, Computational. Statistics Quaterly, vol.2, pp.73-82, 1985. ,
Convergence and robustness of the Robbins-Monro algorithm truncated at randomly varying bounds, Stochastic Processes and their Applications, vol.27, pp.217-231, 1988. ,
DOI : 10.1016/0304-4149(87)90039-1
Estimation of the coefficients of a diffusion from discrete observations, Stochastics, vol.19, issue.4, pp.263-284, 1986. ,
DOI : 10.1070/RM1975v030n01ABEH001400
Convergence of a stochastic approximation version of the EM algorithm, Ann. Statist, vol.27, pp.94-128, 1999. ,
Maximum likelihood from incomplete data via the EM algorithm, J. Roy. Statist. Soc. Ser. B, vol.39, pp.1-38, 1977. ,
Likelihood Inference for Discretely Observed Nonlinear Diffusions, Econometrica, vol.69, issue.4, pp.959-993, 2001. ,
DOI : 10.1111/1468-0262.00226
MCMC Analysis of Diffusion Models With Application to Finance, Journal of Business & Economic Statistics, vol.19, issue.2, 2001. ,
DOI : 10.1198/073500101316970403
Markov chain Monte Carlo in practice. Interdisciplinary Statistics, 1996. ,
Diffusions with measurement errors. I. Local Asymptotic Normality, ESAIM: Probability and Statistics, vol.5, pp.225-242, 2001. ,
DOI : 10.1051/ps:2001110
URL : http://archive.numdam.org/article/PS_2001__5__243_0.pdf
Asympotical normality of the maximum likelihood estimator in state space models, Ann. Statist, vol.27, pp.514-535, 1999. ,
Applications of Pharmacokinetic principles in drug development, 2004. ,
DOI : 10.1007/978-1-4419-9216-1
Coupling a stochastic approximation version of EM with an MCMC procedure, ESAIM: Probability and Statistics, vol.8, pp.115-131, 2004. ,
DOI : 10.1051/ps:2004007
Maximum likelihood estimation in nonlinear mixed effects models, Computational Statistics & Data Analysis, vol.49, issue.4, pp.1020-1038, 2005. ,
DOI : 10.1016/j.csda.2004.07.002
Applications of the malliavin calculus, part II, J. Fac, 1985. ,
Parameter estimation for stochastic processes, 1984. ,
Finding the observed information matrix when using the EM algorithm, J. Roy. Statist. Soc. Ser. B, vol.44, pp.226-233, 1982. ,
Markov chains and stochastic stability, 1993. ,
Non-Linear Mixed-Effects Models with Stochastic Differential Equations: Implementation of an Estimation Algorithm, Journal of Pharmacokinetics and Pharmacodynamics, vol.29, issue.5???6, 2005. ,
DOI : 10.1007/s10928-005-2104-x
A new approach to maximum likelihood estimation for stochastic differential equations based on discrete observations. Scand, J. Statist, vol.22, pp.55-71, 1995. ,
Approximations to the log-likelihood function in the non-linear mixed-effect models, J. Comput. Graph. Statist, vol.4, pp.12-35, 1995. ,
Approximate maximum likelihood estimation of discretely observed diffusion process, 1999. ,
Statistical Inference for Diffusion Type Processes, 1999. ,
DOI : 10.1002/9780470667125
On inference for partially observed nonlinear diffusion models using the Metropolis-Hastings algorithm, Biometrika, vol.88, issue.3, pp.603-621, 2001. ,
DOI : 10.1093/biomet/88.3.603
Evaluation of likelihood functions for Gaussian signals, IEEE Transactions on Information Theory, vol.11, issue.1, pp.61-70, 1965. ,
DOI : 10.1109/TIT.1965.1053737
CONTINUOUS-TIME DYNAMICAL SYSTEMS WITH SAMPLED DATA, ERRORS OF MEASUREMENT AND UNOBSERVED COMPONENTS, Journal of Time Series Analysis, vol.3, issue.8, pp.527-545, 1993. ,
DOI : 10.1098/rsta.1927.0007
Parametric Inference for Diffusion Processes Observed at Discrete Points in Time: a Survey, International Statistical Review, vol.3, issue.3, pp.337-354, 2004. ,
DOI : 10.1111/j.1751-5823.2004.tb00241.x
Prediction-based estimating functions, The Econometrics Journal, vol.3, issue.2, pp.123-147, 2000. ,
DOI : 10.1111/1368-423X.00042
Markov Chains for Exploring Posterior Distributions, The Annals of Statistics, vol.22, issue.4, pp.1701-1762, 1994. ,
DOI : 10.1214/aos/1176325750
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.110.5995
Stochastic differential equations in NONMEM: implementation, application, and comparison Unité de recherche INRIA Futurs Parc Club Orsay Université -ZAC des Vignes 4, 2005. ,
Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex (France) Unité de recherche INRIA Sophia Antipolis : 2004, route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
