Concurrent Secrets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Concurrent Secrets
Eric Badouel
  • Fonction : Auteur
  • PersonId : 833447
Marek Bednarczyk
  • Fonction : Auteur
  • PersonId : 833448
Andrzej Borzyszkowski
  • Fonction : Auteur
  • PersonId : 833449
Given a finite state system with partial observers and for each observer, a regular set of trajectories which we call a secret, we consider the question whether the observers can ever find out that the trajectory of the system belongs to some secret. We search for a regular control on the system, enforcing the specified secrets on the observers, even though they have full knowledge of this control. We show that an optimal control always exists although it is generally not regular. We state sufficient conditions for computing a finite and optimal control of the system enforcing the concurrent secret as desired. We briefly point to applications.
Autre [cs.OH]
RR-5771.pdf (343.4 Ko) Télécharger le fichier
inria-00070249 , version 1 (19-05-2006)
  • HAL Id : inria-00070249 , version 1
Eric Badouel, Marek Bednarczyk, Andrzej Borzyszkowski, Benoit Caillaud, Philippe Darondeau. Concurrent Secrets. [Research Report] RR-5771, INRIA. 2005, pp.22. ⟨inria-00070249⟩
221 Consultations
182 Téléchargements
