An adaptative antidissipative method for optimal control problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
We deal with a numerical method for HJB equations coming from optimal control problems with state constraints. More precisely, we present here an antidissipative scheme applied on an adaptative grid.The adaptative grid is generated using linear quadtree structure. This technique of adaptation facilitates stocking data and dealing with large numerical systems.
Autre [cs.OH]
RR-5770.pdf (397.96 Ko) Télécharger le fichier
inria-00070250 , version 1 (19-05-2006)
  • HAL Id : inria-00070250 , version 1
Olivier Bokanowski, Nadia Megdich, Hasnaa Zidani. An adaptative antidissipative method for optimal control problems. [Research Report] RR-5770, INRIA. 2005, pp.21. ⟨inria-00070250⟩
64 Consultations
59 Téléchargements
