Maximum Entropy Spherical Deconvolution for Diffusion MRI, Image Processing in Medical Imaging, pp.76-87, 2005. ,
DOI : 10.1007/11505730_7
Detection and modeling of non-Gaussian apparent diffusion coefficient profiles in human brain data, Magnetic Resonance in Medicine, vol.46, issue.2, pp.331-340, 2002. ,
DOI : 10.1002/mrm.10209
Special Functions, 1999. ,
MR diffusion tensor spectroscopy and imaging, Biophysical Journal, vol.66, issue.1, pp.259-267, 1994. ,
DOI : 10.1016/S0006-3495(94)80775-1
URL : https://hal.archives-ouvertes.fr/hal-00349721
Characterization and propagation of uncertainty in diffusion-weighted MR imaging, Magnetic Resonance in Medicine, vol.36, issue.5, pp.1077-1088, 2003. ,
DOI : 10.1002/mrm.10609
Diffusion Imaging of White Matter Fiber Tracts, 2004. ,
Flow-based fiber tracking with diffusion tensor and q-ball data: Validation and comparison to principal diffusion direction techniques, NeuroImage, vol.27, issue.4, pp.725-736, 2005. ,
DOI : 10.1016/j.neuroimage.2005.05.014
Recovery of intra-voxel structure from hard dwi, ISBI, pp.1028-1031, 2004. ,
Estimation, smoothing, and characterization of apparent diffusion coefficient profiles from high angular resolution DWI, Proceedings of the 2004 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2004. CVPR 2004., pp.588-593, 2004. ,
DOI : 10.1109/CVPR.2004.1315085
Apparent diffusion coefficients from high angular resolution diffusion imaging: Estimation and applications, Magnetic Resonance in Medicine, vol.50, issue.2, 2005. ,
DOI : 10.1002/mrm.20948
Anisotropy in high angular resolution diffusion-weighted MRI, Magnetic Resonance in Medicine, vol.111, issue.6, pp.935-939, 2001. ,
DOI : 10.1002/mrm.1125
Characterization of anisotropy in high angular resolution diffusion-weighted MRI, Magnetic Resonance in Medicine, vol.15, issue.6, pp.1083-1099, 2002. ,
DOI : 10.1002/mrm.10156
The l-curve and its use in the numerical treatment of inverse problems, Computational Inverse Problems in Electrocardiology, pp.119-142, 2001. ,
White matter tractography using diffusion tensor deflection, Human Brain Mapping, pp.306-321, 2003. ,
DOI : 10.1002/hbm.10102
MR imaging of intravoxel incoherent motions: Application to diffusion and perfusion in neurologic disorders, Radiology, pp.401-407, 1986. ,
Statistics on the Manifold of Multivariate Normal Distributions: Theory and Application to Diffusion Tensor MRI Processing, Journal of Mathematical Imaging and Vision, vol.12, issue.1, 2005. ,
DOI : 10.1007/s10851-006-6897-z
A Riemannian Approach to Diffusion Tensor Images Segmentation, Information Processing in Medical Imaging, pp.591-602, 2005. ,
DOI : 10.1007/11505730_49
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.161.5661
Validation of diffusion spectrum magnetic resonance imaging with manganese-enhanced rat optic tracts and ex vivo phantoms, NeuroImage, vol.19, issue.3, pp.482-495, 2003. ,
DOI : 10.1016/S1053-8119(03)00154-X
Limitations of apparent diffusion coefficient-based models in characterizing non-gaussian diffusion, Magnetic Resonance in Medicine, vol.32, issue.2, pp.419-428, 2005. ,
DOI : 10.1002/mrm.20579
Persistent angular structure: new insights from diffusion magnetic resonance imaging data, Inverse Problems, vol.19, issue.5, pp.1031-1046, 2003. ,
DOI : 10.1088/0266-5611/19/5/303
Generalized diffusion tensor imaging and analytical relationships between diffusion tensor imaging and high angular resolution diffusion imaging, Magnetic Resonance in Medicine, vol.48, issue.5, pp.955-965, 2003. ,
DOI : 10.1002/mrm.10596
Fast Orientation Mapping from HARDI, MICCAI, pp.156-163, 2005. ,
DOI : 10.1007/11566465_20
Resolution of complex tissue microarchitecture using the diffusion orientation transform (DOT), NeuroImage, vol.31, issue.3, 2005. ,
DOI : 10.1016/j.neuroimage.2006.01.024
Generalized scalar measures for diffusion MRI using trace, variance, and entropy, Magnetic Resonance in Medicine, vol.40, issue.4, pp.866-876, 2005. ,
DOI : 10.1002/mrm.20411
Fiber orientation mapping using generalized diffusion tensor imaging, 2004 2nd IEEE International Symposium on Biomedical Imaging: Macro to Nano (IEEE Cat No. 04EX821), pp.1036-1039, 2004. ,
DOI : 10.1109/ISBI.2004.1398718
Fiber Tracking in q-Ball Fields Using Regularized Particle Trajectories, Information Processing in Medical Imaging, pp.52-63, 2005. ,
DOI : 10.1007/11505730_5
URL : https://hal.archives-ouvertes.fr/hal-00349651
Détection des faisceaux de fibres de la substance blanche pour l'étude de la connectivité anatomique cérébrale, 1999. ,
Cumulative Residual Entropy: A New Measure of Information, IEEE Transactions on Information Theory, vol.50, issue.6, pp.1220-1228, 2004. ,
DOI : 10.1109/TIT.2004.828057
3D Curve Inference for Diffusion MRI Regularization, MICCAI, pp.123-130, 2005. ,
DOI : 10.1007/11566465_16
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.59.9357
Estimation of the Noise in Magnitude MR Images, Magnetic Resonance Imaging, vol.16, issue.1, pp.87-90, 1998. ,
DOI : 10.1016/S0730-725X(97)00199-9
Signal and Noise Estimation from Magnetic Resonance Images, 1998. ,
Restricted Diffusion in Cylindrical Geometry, Journal of Magnetic Resonance, Series A, vol.117, issue.1, pp.94-97, 1995. ,
DOI : 10.1006/jmra.1995.0014
Mathematical Handbook of Formulas and Tables. Schaum's Outlines, 1999. ,
Spin Diffusion Measurements: Spin Echoes in the Presence of a Time???Dependent Field Gradient, The Journal of Chemical Physics, vol.42, issue.1, pp.288-292, 1965. ,
DOI : 10.1063/1.1695690
Direct estimation of the fiber orientation density function from diffusion-weighted MRI data using spherical deconvolution, NeuroImage, vol.23, issue.3, pp.1176-1185, 2004. ,
DOI : 10.1016/j.neuroimage.2004.07.037
Variational frameworks for DT-MRI estimation, regularization and visualization, Proceedings Ninth IEEE International Conference on Computer Vision, pp.116-121, 2003. ,
DOI : 10.1109/ICCV.2003.1238323
Diffusion MRI of Complex Tissue Structure, 2002. ,
Q-ball imaging, Magnetic Resonance in Medicine, vol.23, issue.6, pp.1358-1372, 2004. ,
DOI : 10.1002/mrm.20279
High angular resolution diffusion imaging reveals intravoxel white matter fiber heterogeneity, Magnetic Resonance in Medicine, vol.147, issue.4, pp.577-582, 2002. ,
DOI : 10.1002/mrm.10268
Q-ball imaging of macaque white matter architecture, Philosophical Transactions of the Royal Society B: Biological Sciences, vol.217, issue.3, pp.869-879, 2005. ,
DOI : 10.1016/S0361-9230(99)00229-4
Simultaneous smoothing and estimation of the tensor field from diffusion tensor MRI, 2003 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2003. Proceedings., pp.461-466, 2003. ,
DOI : 10.1109/CVPR.2003.1211390
Mapping fiber orientation spectra in cerebral white matter with fourier-transform diffusion mri, Proceedings of the International Society for the Magnetic Resonance in Medecine, p.321, 1999. ,
Processing and visualization for diffusion tensor MRI In In proceedings of Medical Image Analysis, route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex, pp.93-108, 2002. ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
