Proving Correctness of Highly-Concurrent Linearisable Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Viktor Vafeiadis
  • Fonction : Auteur
Maurice Herlihy
  • Fonction : Auteur
Tony Hoare
  • Fonction : Auteur
Marc Shapiro
We study a family of implementations for linked lists using fine-grain synchronisation. This approach enables greater concurrency, but correctness is a greater challenge than for classical, coarse-grain synchronisation. Our examples are demonstrative of common design patterns such as lock coupling, optimistic, and lazy synchronisation. Although they are are highly concurrent, we prove that they are linearisable, safe, and they correctly implement a high-level abstraction. Our proofs illustrate the power and applicability of rely-guarantee reasoning, as well of some of its limitations. The examples of the paper establish a benchmark challenge for other reasoning techniques.
RR-5716.pdf (299.09 Ko) Télécharger le fichier
inria-00070301 , version 1 (19-05-2006)
  • HAL Id : inria-00070301 , version 1
Viktor Vafeiadis, Maurice Herlihy, Tony Hoare, Marc Shapiro. Proving Correctness of Highly-Concurrent Linearisable Objects. [Research Report] RR-5716, INRIA. 2005, pp.20. ⟨inria-00070301⟩
152 Consultations
218 Téléchargements
