The Radial Spanning Tree of a Poisson Point Process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
We analyze a class of random spanning trees built on a realization of an homogeneous Poisson point process of the plane. This tree has a local construction rule and a radial structure with the origin as its root We first use stochastic geometry arguments to analyze local functionals of the random tree such as the distribution of the length of the edges or the mean degree of the vertices. Far away from the origin, these local properties are shown to be close to those of the directed spanning tree introduced by Bhatt and Roy. We then use the theory of continuous state space Markov chains to analyze some non local properties of the tree such as the shape and structure of its semi-infinite paths or the shape of the set of its vertices less than $k$ generations away from the origin. This class of spanning trees has applications in many fields and in particular in communications.
RR-5707.pdf (1.19 Mo) Télécharger le fichier
inria-00070309 , version 1 (19-05-2006)
  • HAL Id : inria-00070309 , version 1
François Baccelli, Charles Bordenave. The Radial Spanning Tree of a Poisson Point Process. [Research Report] RR-5707, INRIA. 2005, pp.73. ⟨inria-00070309⟩
246 Consultations
169 Téléchargements
