A fictitious domain/mortar element method for fluid-structure interaction, International Journal for Numerical Methods in Fluids, vol.79, issue.7, pp.743-761, 2001. ,
DOI : 10.1002/1097-0363(20010415)35:7<743::AID-FLD109>3.0.CO;2-A
Domain decomposition by the mortar element method In Asymptotic and numerical methods for partial differential equations with critical parameters, NATO Adv. Sci. Inst. Ser. C Math. Phys. Sci, vol.384, pp.269-286, 1992. ,
Added-mass effect in the design of partitioned algorithms for fluid???structure problems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.42-44, pp.42-444506, 2005. ,
DOI : 10.1016/j.cma.2004.12.005
URL : https://hal.archives-ouvertes.fr/inria-00071499
The Finite Element Analysis of Shells -Fundamentals, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00839738
Numerical solution of the Navier-Stokes equations, Mathematics of Computation, vol.22, issue.104, pp.745-762, 1968. ,
DOI : 10.1090/S0025-5718-1968-0242392-2
On the convergence of discrete approximations to the Navier-Stokes equations, Mathematics of Computation, vol.23, issue.106, pp.341-353, 1969. ,
DOI : 10.1090/S0025-5718-1969-0242393-5
Approximation by finite element functions using local regularization, Rev. Française Automat. Informat. Recherche Opérationnelle Sér. RAIRO Analyse Numérique, vol.9, issue.2, pp.77-84, 1975. ,
A three-dimensional computational analysis of fluid???structure interaction in the aortic valve, Journal of Biomechanics, vol.36, issue.1, pp.103-112, 2003. ,
DOI : 10.1016/S0021-9290(02)00244-0
Heterogeneous Domain Decomposition Methods for Fluid-Structure Interaction Problems, 2005. ,
DOI : 10.1007/978-3-540-34469-8_4
A domain decomposition framework for fluidstructure interaction problems, Proceedings of the Third International Conference on Computational Fluid Dynamics (ICCFD3), 2004. ,
Acceleration of a fixed point algorithm for fluid-structure interaction using transpiration conditions, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.4, pp.601-616, 2003. ,
DOI : 10.1051/m2an:2003050
URL : https://hal.archives-ouvertes.fr/hal-00705114
A Dynamic Preconditioner for Newton-Krylov Algorithms. Application to Fluid-Structure Interaction, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00070650
An arbitrary lagrangian-eulerian finite element method for transient dynamic fluid-structure interactions, Computer Methods in Applied Mechanics and Engineering, vol.33, issue.1-3, pp.689-723, 1982. ,
DOI : 10.1016/0045-7825(82)90128-1
Theory and practice of finite elements, Applied Mathematical Sciences, vol.159, 2004. ,
DOI : 10.1007/978-1-4757-4355-5
Load and motion transfer algorithms for fluid/structure interaction problems with non-matching discrete interfaces: Momentum and energy conservation, optimal discretization and application to aeroelasticity, Computer Methods in Applied Mechanics and Engineering, vol.157, issue.1-2, pp.95-114, 1998. ,
DOI : 10.1016/S0045-7825(97)00216-8
Provably second-order time-accurate looselycoupled solution algorithms for transient nonlinear aeroelasticity ,
Underwater shock on stiffened shells: the source of Staggered Solution Procedure, 5th international Conference on Computational of Shell & Spatial Structures. IASS-IACM, 2005. ,
Finite element analysis of shock-induced hull cavitation, Computer Methods in Applied Mechanics and Engineering, vol.44, issue.3, pp.297-337, 1984. ,
DOI : 10.1016/0045-7825(84)90134-8
Numerical simulation of fluid-structure systems via Newton's method with exact Jacobians, 4 th European Congress on Computational Methods in Applied Sciences and Engineering, 2004. ,
An exact block-Newton algorithm for solving fluidstructure interaction problems, C. R. Math. Acad. Sci. Paris, issue.8, pp.336681-686, 2003. ,
An exact block-newton algorithm for the solution of implicit time discretized coupled systems involved in fluid-structure interaction problems, Second M.I.T. Conference on Computational Fluid and Solid Mechanics, pp.1337-1341, 2003. ,
A Newton method using exact jacobians for solving fluid???structure coupling, Computers & Structures, vol.83, issue.2-3, pp.127-142, 2005. ,
DOI : 10.1016/j.compstruc.2004.04.021
A coupled momentum method for modeling blood flow in three-dimensional deformable arteries, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.41-43 ,
DOI : 10.1016/j.cma.2005.11.011
On the coupling of 3D and 1D Navier???Stokes equations for flow problems in compliant vessels, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.6-7, pp.6-7561, 2001. ,
DOI : 10.1016/S0045-7825(01)00302-4
URL : https://hal.archives-ouvertes.fr/inria-00072794
A quasi-Newton method for a fluid-structure problem arising in blood flows, Proceedings of the second M.I.T. Conference on Computational Fluid and Solid Mechanics, pp.1355-1357, 2003. ,
DOI : 10.1016/B978-008044046-0.50332-8
A Quasi-Newton Algorithm Based on a Reduced Model for Fluid-Structure Interaction Problems in Blood Flows, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.4, pp.631-648, 2003. ,
DOI : 10.1051/m2an:2003049
URL : https://hal.archives-ouvertes.fr/inria-00071895
Fluid???structure interaction in blood flows on geometries based on medical imaging, Computers & Structures, vol.83, issue.2-3, pp.155-165, 2005. ,
DOI : 10.1016/j.compstruc.2004.03.083
Nonconforming grids for the simulation of fluid-structure interaction In Domain decomposition methods, Contemp. Math, vol.10, issue.218, pp.262-270, 1997. ,
An overview of projection methods for incompressible flows, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.44-47, 2004. ,
DOI : 10.1016/j.cma.2005.10.010
On stability and convergence of projection methods based on pressure Poisson equation, International Journal for Numerical Methods in Fluids, vol.95, issue.9, pp.1039-1053, 1998. ,
DOI : 10.1002/(SICI)1097-0363(19980515)26:9<1039::AID-FLD675>3.0.CO;2-U
Fluid structure interaction with large structural displacements, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.24-25, pp.3039-3067, 2001. ,
DOI : 10.1016/S0045-7825(00)00381-9
Partitioned but strongly coupled iteration schemes for nonlinear fluid???structure interaction, Computers & Structures, vol.80, issue.27-30, pp.27-301991, 2002. ,
DOI : 10.1016/S0045-7949(02)00259-6
Strong Coupling Methods, 2002. ,
DOI : 10.1007/978-3-540-36527-3_2
Partitioned strong coupling algorithms for fluid???structure interaction, Computers & Structures, vol.81, issue.8-11, pp.805-812, 2003. ,
DOI : 10.1016/S0045-7949(02)00409-1
An interface Newton-Krylov solver for fluid-structure interaction, International Journal for Numerical Methods in Fluids, vol.192, issue.10-11, pp.10-111189, 2005. ,
DOI : 10.1002/fld.850
Partitioned analysis schemes for the transient interaction of incompressible flows and nonlinear flexible structures, Trends in computational structural mechanics, 2001. ,
Partitioned analysis approach for the transient, coupled response of viscous fluids and flexible structures, Proceedings of the European Conference on Computational Mechanics. ECCM'99, 1999. ,
Accelerated iterative substructuring schemes for instationary fluid-structure interaction, Computational Fluid and Solid Mechanics, pp.1325-1328, 2001. ,
DOI : 10.1016/B978-008043944-0/50907-0
Numerical approximation of fluid-structure interaction problems with application to haemodynamics, 2001. ,
A computational strategy for interaction of fluid flow with spatial structures, 5th international Conference on Computational of Shell & Spatial Structures. IASS-IACM, 2005. ,
Explicit/implicit fluid/structure staggered procedures with a structural predictor and fluid subcycling for 2D inviscid aeroelastic simulations, International Journal for Numerical Methods in Fluids, vol.134, issue.10, pp.251207-1226, 1997. ,
DOI : 10.1002/(SICI)1097-0363(19971130)25:10<1207::AID-FLD616>3.0.CO;2-R
URL : https://hal.archives-ouvertes.fr/hal-00607776
Partitioned procedures for the transient solution of coupled aroelastic problems Part I: Model problem, theory and two-dimensional application, Computer Methods in Applied Mechanics and Engineering, vol.124, issue.1-2, pp.79-112, 1995. ,
DOI : 10.1016/0045-7825(95)92707-9
Fluid-structure interaction boundary conditions by artificial compressibility, ECCOMAS Computational Fluid Dynamics Conference, 2001. ,
On finite element analysis of fluid flows coupled with structural interaction. CMES -Comp, Modeling Eng. Sci, vol.2, issue.2, pp.195-212, 2001. ,
Une méthode d'approximation de la solution deséquationsdeséquations de Navier-Stokes, Bull. Soc. Math. France, vol.96, pp.115-152, 1968. ,
Finite Element Methods for Fluid Dynamics with Moving Boundaries and Interfaces, Arch. Comput. Methods Engrg, vol.8, pp.83-130, 2001. ,
DOI : 10.1002/0470091355.ecm069
Recent development of fluid???structure interaction capabilities in the ADINA system, Computers & Structures, vol.81, issue.8-11, pp.8-111071, 2003. ,
DOI : 10.1016/S0045-7949(03)00009-9
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-l` es-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche, 2004. ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
