HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Electrocap: A Shape Inverse Model for an Electro-Capillarity Process
Jerome Monnier 1 Patrick Chow-Wing-Bom
1 IDOPT - System identification and optimization in physics and environment
Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : UMR5527
Abstract : Electrocap is a freeware modelling an electrified droplet at equilibrium and wetting a solid surface. The model consists to seek the drop shape by minimizing its total energy (capillary, electrostatic and gravitational). To this end, the model is based on the classical shape optimal design method. In this paper, we derive the equations and the shape gradient; we detail the shape optimization algorithm implemented and present some numerical results. The code is based on the public mesh generator Bamg and the public C++ finite element library Rheolef.
Document type :
Reports
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/inria-00070391
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 8:22:16 PM
Last modification on : Thursday, February 3, 2022 - 11:15:35 AM
Long-term archiving on: : Tuesday, February 22, 2011 - 11:43:34 AM
Identifiers
  • HAL Id : inria-00070391, version 1
Collections
Citation
Jerome Monnier, Patrick Chow-Wing-Bom. Electrocap: A Shape Inverse Model for an Electro-Capillarity Process. RR-5617, INRIA. 2005, pp.30. ⟨inria-00070391⟩
Share
Metrics
Record views
112
Files downloads
251
