Variable focal lens controlled by an external voltage: An application of electrowetting, The European Physical Journal E, vol.3, issue.2, pp.159-163, 2000. ,
DOI : 10.1007/s101890070029
Modification of Drop Shape Controlled by Electrowetting, Langmuir, vol.19, issue.22, pp.9328-9361, 2003. ,
DOI : 10.1021/la030079w
Conception optimale ou identification de formes -Calcul rapide de la dérivée directionnelle de la fonction coût, M2AN, pp.371-402, 1986. ,
Shape Optimal Design Problem with Convective and Radiative Heat Transfer: Analysis and Implementation, Journal of Optimization Theory and Applications, vol.8, issue.2, 2001. ,
DOI : 10.1023/A:1017543529204
Applied optimal shape design for fluids, 2001. ,
Shape sensitivities in a Navier-Stokes flow with convective and grey bodies radiative thermal transfer, Optimal Control Applications and Methods, vol.10, issue.5, pp.237-256, 2003. ,
DOI : 10.1002/oca.728
Limiting phenomena for the spreading of water on polymer films by electrowetting, The European Physical Journal B, vol.11, issue.4, p.583, 1999. ,
DOI : 10.1007/s100510051186
Alpes 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4 ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rocquencourt : Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex (France) Unité de recherche, 2004. ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
