A central limit theorem and improved error bounds for a hybrid-Monte Carlo sequence with applications in computational finance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
In problems of moderate dimensions, the quasi-Monte Carlo method usually provides better estimates than the Monte Carlo method. However, as the dimension of the problem increases, the advantages of the quasi-Monte Carlo method diminish quickly. A remedy for this problem is to use hybrid sequences; sequences that combine pseudorandom and low-discrepancy vectors. In this paper we discuss a particular hybrid sequence called the mixed sequence. We will provide improved discrepancy bounds for this sequence and prove a central limit theorem for the corresponding estimator. We will also provide numerical results that compare the mixed sequence with the Monte Carlo and randomized quasi-Monte Carlo methods.
Autre [cs.OH]
RR-5600.pdf (312.99 Ko) Télécharger le fichier
inria-00070407 , version 1 (19-05-2006)
  • HAL Id : inria-00070407 , version 1
Giray Ökten, Bruno Tuffin, Vadim Burago. A central limit theorem and improved error bounds for a hybrid-Monte Carlo sequence with applications in computational finance. [Research Report] RR-5600, INRIA. 2005, pp.28. ⟨inria-00070407⟩
154 Consultations
189 Téléchargements
