Stabilization of a class of Delay Systems using PI methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Jonathan R. Partington
  • Fonction : Auteur
We study in this report the $H_\infty$-stabilizing properties of PI controllers for particular SISO delay systems of three classes : dead-time systems as well as retarded or neutral systems. For a subclass of neutral systems, this enables us to deduce a parametrization of all $H_\infty$-stabilizing controllers.
Autre [cs.OH]
RR-5583.pdf (231.62 Ko) Télécharger le fichier
inria-00070424 , version 1 (19-05-2006)
  • HAL Id : inria-00070424 , version 1
Catherine Bonnet, Jonathan R. Partington. Stabilization of a class of Delay Systems using PI methods. [Research Report] RR-5583, INRIA. 2005, pp.13. ⟨inria-00070424⟩
68 Consultations
92 Téléchargements
