Supporting efficient execution in heterogeneous distributed computing environments with cactus and globus, Proceedings of the 2001 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '01, pp.52-76, 2001. ,
DOI : 10.1145/582034.582086
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.4394
Configuration description, deployment, and lifecycle management. CDDLM working group of the global grid forum, 2003. ,
Scheduling malleable tasks on parallel processors to minimize the makespan, Annals of Operations Research, pp.129-130, 2004. ,
Grid information services for distributed resource sharing, Proceedings 10th IEEE International Symposium on High Performance Distributed Computing, pp.181-194, 2001. ,
DOI : 10.1109/HPDC.2001.945188
Accurately measuring MPI broadcasts in a computational grid, 8th Symp. on High Performance Distributed Computing (HPDC), pp.29-37, 1999. ,
Exploiting hierarchy in parallel computer networks to optimize collective operation performance, Proceedings 14th International Parallel and Distributed Processing Symposium. IPDPS 2000, pp.377-384, 2000. ,
DOI : 10.1109/IPDPS.2000.846009
MPICH-G2: a grid-enabled implementation of the message passing interface, Journal of Parallel and Distributed Computing (JPDC), vol.63, issue.5, pp.551-563, 2003. ,
MPI development tools and applications for the grid, Workshop on Grid Applications and Programming Tools, 2003. ,
Network performance-aware collective communication for clustered wide-area systems, Parallel Computing, vol.27, issue.11, pp.1431-1456, 2001. ,
DOI : 10.1016/S0167-8191(01)00098-9
Deploying CORBA Components on a Computational Grid: General Principles and Early Experiments Using the Globus Toolkit, 2nd Int'l Working Conf. on Component Deployment number 3083 in LNCS, pp.35-49, 2004. ,
DOI : 10.1007/978-3-540-24848-4_3
URL : https://hal.archives-ouvertes.fr/inria-00071435
A Network Topology Description Model for Grid Application Deployment, Fifth IEEE/ACM International Workshop on Grid Computing, pp.61-68, 2004. ,
DOI : 10.1109/GRID.2004.2
URL : https://hal.archives-ouvertes.fr/inria-00070773
A software architecture for automatic deployment of CORBA components using grid technologies, 1st Francophone Conf. On Software Deployment and (Re)Configuration, pp.187-192, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00003294
A hierarchy of network performance characteristics for grid applications and services. Proposed Recommendation Global Grid Forum, Network Measurement Working Group (NMWG), 2004. ,
Multivariate geographic clustering in a metacomputing environment using Globus, Proceedings of the 1999 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '99, pp.5-16, 1999. ,
DOI : 10.1145/331532.331537
A Realistic Network/Application Model for Scheduling Divisible Loads on Large-Scale Platforms, 19th IEEE International Parallel and Distributed Processing Symposium, 2005. ,
DOI : 10.1109/IPDPS.2005.63
URL : https://hal.archives-ouvertes.fr/inria-00070795
Mapping strategies for switch-based cluster systems of irregular topology, 8th Int'l Conf. on Parallel and Distributed Systems, pp.733-740, 2001. ,
A new task mapping technique for communicationaware scheduling strategies, 30th Int'l Workshops on Parallel Processing (ICPP), pp.349-354, 2001. ,
A parallel CORBA component model for numerical code coupling. The Int, Journal of High Performance Computing Applications (IJHPCA), pp.417-429, 2003. ,
Matchmaking: distributed resource management for high throughput computing, Proceedings. The Seventh International Symposium on High Performance Distributed Computing (Cat. No.98TB100244), pp.140-146, 1998. ,
DOI : 10.1109/HPDC.1998.709966
A comparison study of static mapping heuristics for a class of meta-tasks on heterogeneous computing systems, Proceedings. Eighth Heterogeneous Computing Workshop (HCW'99), pp.15-29, 1999. ,
DOI : 10.1109/HCW.1999.765093
Implementing the MPI Process Topology Mechanism, ACM/IEEE SC 2002 Conference (SC'02), pp.1-14, 2002. ,
DOI : 10.1109/SC.2002.10045
The open software description format (OSD), 1997. ,
On Benchmarking Collective MPI Operations, 9th European PVM/MPI Users' Group Meeting, number 2474 in LNCS, pp.271-279, 2002. ,
DOI : 10.1007/3-540-45825-5_43
Campus scientifique, 615 rue du Jardin Botanique Irisa, Campus universitaire de Beaulieu, 35042 RENNES Cedex Unité de recherche INRIA Rhône-Alpes, p.78153, 2004. ,
