HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Quiescence Management improves Interoperability Testing
Alexandra Desmoulin 1 César Viho 1
1 ARMOR - Architectures and network models
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes, Ecole Nationale Supérieure des Télécommunications de Bretagne
Abstract : At any level of computer networks, interoperability testing generally deals with several components that communicate while trying to provide a designated service. When a component remains silent, the assigned testing verdict is generally Fail, assuming that its behavior is non-conformant. Sometimes, this silence may be anticipated given the component's specifications. In these cases, the fail verdict is unsatisfactory. In this paper, we show that ``quiescence management'' improves interoperability testing. Based on formal definitions of interoperability testing, we introduce new definitions that take into account the possible quiescence of components under test. Through several examples and scenarios, we show that these new definitions detect non-interoperability cases with higher precision. Moreover, these new definitions more clearly distinguish specification-driven quiescences from others, leading to unbiased interoperability tests with accurate verdicts.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00070477
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 8:36:41 PM
Last modification on : Friday, February 4, 2022 - 3:21:59 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:18:20 PM
Identifiers
  • HAL Id : inria-00070477, version 1
Citation
Alexandra Desmoulin, César Viho. Quiescence Management improves Interoperability Testing. [Research Report] RR-5530, INRIA. 2005, pp.18. ⟨inria-00070477⟩
Share
Metrics
Record views
114
Files downloads
98
