HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Upper Bounds on the Dual Distances of EBCH Codes
Carmen-Simona Nedeloaia 1
1 CODES - Coding and cryptography
Inria Paris-Rocquencourt
Abstract : We give new upper bounds on the dual distances of extended BCH codes of length 512. First, we apply a probabilistic algorithm due to Canteaut and Chabaud. Secondly, we put these codes in standard bit order and we use the twisted squaring decomposition of affine-invariant codes. We then obtain two subcodes which contain codewords of minimum weights for the duals of BCH codes of length less than or equal to 512. This decomposition also gives new interesting codes of smaller length, which sometimes are found to be Reed-Muller codes.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00070530
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 8:47:02 PM
Last modification on : Thursday, February 3, 2022 - 11:14:37 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:24:51 PM
Identifiers
  • HAL Id : inria-00070530, version 1
Collections
Citation
Carmen-Simona Nedeloaia. Upper Bounds on the Dual Distances of EBCH Codes. [Research Report] RR-5477, INRIA. 2005, pp.14. ⟨inria-00070530⟩
Share
Metrics
Record views
44
Files downloads
93
