An anti-diffusive scheme for viability problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Olivier Bokanowski
Sophie Martin
Remi Munos
  • Fonction : Auteur
This paper is concerned with numerical approximation of viability kernels. We use a characterization of the viability kernel by the value function of an optimal control problem. Since this value function is discontinuous, usual discretization schemes (such as finite differences) provide poor approximation quality because of numerical diffusion. We investigate the use of the ultra-bee scheme for its anti-diffusive property in the transport of discontinuous functions. Numerical experiments, compared with the viability algorithm , show the relevance of this scheme for computing viability kernels and capture basins on several benchmark problems.
Autre [cs.OH]
RR-5431.pdf (796.72 Ko) Télécharger le fichier
inria-00070576 , version 1 (19-05-2006)
  • HAL Id : inria-00070576 , version 1
Olivier Bokanowski, Sophie Martin, Remi Munos, Hasnaa Zidani. An anti-diffusive scheme for viability problems. [Research Report] RR-5431, INRIA. 2004, pp.20. ⟨inria-00070576⟩
125 Consultations
117 Téléchargements
