HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
The max-plus Martin boundary
Abstract : We develop an idempotent version of probabilistic potential theory. The goal is to describe the set of max-plus harmonic functions, which give the stationary solutions of deterministic optimal control problems with additive reward. The analogue of the Martin compactification is seen to be a generalisation of the compactification of metric spaces using (generalised) Busemann functions. We define an analogue of the minimal Martin boundary and show that it can be identified with the set of limits of ``almost-geodesics'', and also the set of (normalised) harmonic functions that are extremal in the max-plus sense. Our main result is a max-plus analogue of the Martin representation theorem, which represents harmonic functions by measures supported on the minimal Martin boundary.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00070578
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 8:55:51 PM
Last modification on : Thursday, February 3, 2022 - 11:18:17 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:30:26 PM
Identifiers
  • HAL Id : inria-00070578, version 1
Collections
Citation
Marianne Akian, Stéphane Gaubert, Cormac Walsh. The max-plus Martin boundary. [Research Report] RR-5429, INRIA. 2004, pp.30. ⟨inria-00070578⟩
Share
Metrics
Record views
105
Files downloads
133
