HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
On the ASTA Property in a Feedback Processor-Sharing Queue
Abstract : A stationary M/M/1 Processor-Sharing queue with Bernoulli feedbacks is considered in this paper. Jobs arrive externally with rate $\lambda$ and require services whose average is $1/\mu$; after completing a service, a job leaves the system with probability $\alpha$ and rejoins the queue with probability $1-\alpha$. The queue is stable when the offered load, $\rho= \lambda/(\alpha\mu)$, satisfies $\rho<1$. The distribution of the queue seen by a tagged job which has joined the queue $n$ times already is investigated.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00070583
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 8:56:32 PM
Last modification on : Friday, January 21, 2022 - 3:18:10 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:31:11 PM
Identifiers
  • HAL Id : inria-00070583, version 1
Collections
Citation
Isi Mitrani, Philippe Robert. On the ASTA Property in a Feedback Processor-Sharing Queue. [Research Report] RR-5423, INRIA. 2004, pp.7. ⟨inria-00070583⟩
Share
Metrics
Record views
72
Files downloads
109
