A Probabilistic Analysis of Some Tree Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Hanene Mohamed
  • Fonction : Auteur
  • PersonId : 829697
In this paper a general class of tree algorithms is analyzed. It is shown that, by using an appropriate probabilistic representation of the quantities of interest, the asymptotic behavior of these algorithms can be obtained quite easily without resorting to complex analysis techniques as it is usually the case. This approach gives a unified probabilistic treatment of these questions. It simplifies and extends some of the results known in this domain.
RR-5420.pdf (392.99 Ko) Télécharger le fichier
inria-00070586 , version 1 (19-05-2006)
  • HAL Id : inria-00070586 , version 1
Hanene Mohamed, Philippe Robert. A Probabilistic Analysis of Some Tree Algorithms. [Research Report] RR-5420, INRIA. 2005, pp.31. ⟨inria-00070586⟩
75 Consultations
198 Téléchargements
