HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Qualitative Simulation of the Nutritional Stress Response in Escherichia coli
Abstract : In case of nutritional stress, Escherichia coli cells abandon their exponentially-growing state to enter a more resistant, non- or slow-growing state termed stationary phase. This growth-phase transition is controlled by a genetic regulatory network integrating various environmental signals. Although E. coli is a paradigm of the bacterial world, it is not known how its adaptative response to nutritional conditions emerges from the interactions between the different components of the genetic network. Moreover little quantitative data on kinetic parameters and molecular concentrations are available. To overcome these constraints, we use a qualitative simulation method to model the nutritional stress response network and to simulate the response of E. coli cells to nutrient deprivation. Using this method, we are able to capture essential features of the transition between exponential and stationary phase and to make new predictions concerning the system behavior, that are currently under experimental validation.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00070594
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 8:58:02 PM
Last modification on : Friday, February 4, 2022 - 3:14:45 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:32:31 PM
Identifiers
  • HAL Id : inria-00070594, version 1
Collections
Citation
Delphine Ropers, Hidde de Jong, Michel Page, Dominique Schneider, Johannes Geiselmann. Qualitative Simulation of the Nutritional Stress Response in Escherichia coli. [Research Report] RR-5412, INRIA. 2004, pp.39. ⟨inria-00070594⟩
Share
Metrics
Record views
449
Files downloads
137
