HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Utility maximization in an insider influenced market
Arturo Kohatsu-Higa Agnès Sulem 1
1 MATHFI - Financial mathematics
Inria Paris-Rocquencourt, ENPC - École des Ponts ParisTech, UPEC UP12 - Université Paris-Est Créteil Val-de-Marne - Paris 12
Abstract : We study a controlled stochastic system whose state is described by a stochastic differential equation where the coefficients are anticipating. This setting is used to interpret markets where insiders have some influence on the dynamics of prices. We give a characterization theorem for the optimal logarithmic portfolio of an investor with a different information flow from that of the insider. As examples, we provide explicit results in the partial information case which we extend in order to incorporate the enlargement of filtration techniques for markets with insiders. Finally, we consider a market with an insider which influences the drift of the asset process. This last example, which does not seem to fit into the enlargement of filtration set-up, gives a situation where it makes a difference for a small agent to acknowledge the existence of the insider in the market.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00070624
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 9:02:35 PM
Last modification on : Friday, February 4, 2022 - 3:12:53 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:35:58 PM
Identifiers
  • HAL Id : inria-00070624, version 1
Collections
Citation
Arturo Kohatsu-Higa, Agnès Sulem. Utility maximization in an insider influenced market. [Research Report] RR-5379, INRIA. 2004, pp.31. ⟨inria-00070624⟩
Share
Metrics
Record views
60
Files downloads
170
