Edge Stabilization for the Incompressible Navier-Stokes Equations: a Continuous Interior Penalty Finite Element Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Erik Burman
  • Fonction : Auteur
Peter Hansbo
  • Fonction : Auteur
In this work we present an extension of the continuous interior penalty method of Douglas and Dupont [Lecture Notes in Phys., Vol. 58 (1976) 207] to the incompressible Navier-Stokes equations. The method consists of a stabilized Galerkin formulation using equal order interpolation for pressure and velocity. To counter instabilities due to the pressure/velocity coupling, or due to high local Reynolds number, we add a stabilization term giving $L^2$-control of the jump of the gradient over element edges (faces in 3D) to the standard Galerkin formulation. Boundary conditions are imposed in a weak sense using a consistent penalty formulation due to Nitsche. We prove energy type a priori error estimates independent of the local Reynolds number and give some numerical examples recovering the theoretical results.
Autre [cs.OH]
RR-5349.pdf (1.12 Mo) Télécharger le fichier
inria-00070653 , version 1 (19-05-2006)
  • HAL Id : inria-00070653 , version 1
Erik Burman, Miguel Angel Fernández, Peter Hansbo. Edge Stabilization for the Incompressible Navier-Stokes Equations: a Continuous Interior Penalty Finite Element Method. [Research Report] RR-5349, INRIA. 2004, pp.34. ⟨inria-00070653⟩
147 Consultations
630 Téléchargements
