Perturbation analysis of second-order cone programming problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Héctor Ramírez C
  • Fonction : Auteur
We discuss first and second order optimality conditions for nonlinear second-order cone programming problems, and their relation with semidefinite programming problems. For doing this we extend in an abstract setting the notion of optimal partition. Then we state a characterization of strong regularity.
RR-5293.pdf (323.6 Ko) Télécharger le fichier
inria-00070707 , version 1 (19-05-2006)
  • HAL Id : inria-00070707 , version 1
J. Frederic Bonnans, Héctor Ramírez C. Perturbation analysis of second-order cone programming problems. [Research Report] RR-5293, INRIA. 2004, pp.23. ⟨inria-00070707⟩
64 Consultations
268 Téléchargements
