Performance Analysis and Stochastic Stability of Congestion Control Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
We study an Adaptive Window Protocol (AWP) with a general increase and decrease profiles in the presence of window dependent random losses. We derive a steady-state Kolmogorov equation and then obtain its solution in analytic form. We then derive from the model some monotonicity properties of the window size process. These monotonicity properties are then used to obtain a necessary and sufficient condition for stability of the window evolution process. Finally, we apply the general results to particular TCP versions such as New Reno TCP, Scalable TCP and HighSpeed TCP.
RR-5262.pdf (561.46 Ko) Télécharger le fichier
inria-00070736 , version 1 (19-05-2006)
  • HAL Id : inria-00070736 , version 1
Eitan Altman, Konstantin Avrachenkov, Arzad A. Kherani, Balakrishna Prabhu. Performance Analysis and Stochastic Stability of Congestion Control Protocols. [Research Report] RR-5262, Inria Sophia Antipolis; INRIA. 2004, pp.56. ⟨inria-00070736⟩
107 Consultations
139 Téléchargements
