Detecting codimension-two objects in an image with Ginzburg-Landau models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Jean-François Aujol
Laure Blanc-Féraud
In this paper, we propose a new mathematical model for detecting in an image singularities of codimension greater than or equal to two. This means we want to detect points in a 2-D image or points and curves in a 3-D image. We drew one's inspiration from Ginzburg-Landau (G-L) models which have proved their efficiency for modeling many phenomena in physics. We introduce the model, state its mathematical properties and give some experimental results demonstrating its capability.
RR-5254.pdf (509.07 Ko) Télécharger le fichier
inria-00070744 , version 1 (19-05-2006)
  • HAL Id : inria-00070744 , version 1
Gilles Aubert, Jean-François Aujol, Laure Blanc-Féraud. Detecting codimension-two objects in an image with Ginzburg-Landau models. RR-5254, INRIA. 2004, pp.28. ⟨inria-00070744⟩
102 Consultations
232 Téléchargements
