A Simple Constraint-solving Decision Procedure for Protocols with Exclusive or - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
We present a procedure for deciding security of protocols employing the Exclusive or operator. This procedure relies on a direct combination of a constraint solver for security protocol with a unification algorithm for the exclusive-or theory. Hence compared to the previous ones it is much simpler and easily amenable to automation. The principle of the approach can be applied to other theories too.
Autre [cs.OH]
RR-5224.pdf (301.79 Ko) Télécharger le fichier
inria-00070771 , version 1 (19-05-2006)
  • HAL Id : inria-00070771 , version 1
Yannick Chevalier. A Simple Constraint-solving Decision Procedure for Protocols with Exclusive or. [Research Report] RR-5224, INRIA. 2004, pp.35. ⟨inria-00070771⟩
65 Consultations
62 Téléchargements
