Enabling Applications on the Grid: A Gridlab Overview, JHPCA), special issue on Grid Computing: Infrastructure and Applications, 2003. ,
DOI : 10.1177/10943420030174008
Analysis of the Globus Toolkit grid information service, 2002. ,
First GridLabMDS release, 2002. ,
Toward a common component architecture for high-performance scientific computing, Proceedings. The Eighth International Symposium on High Performance Distributed Computing (Cat. No.99TH8469), pp.13-22, 1999. ,
DOI : 10.1109/HPDC.1999.805289
Myrinet: a gigabit-per-second local area network, IEEE Micro, vol.15, issue.1, pp.29-36, 1995. ,
DOI : 10.1109/40.342015
Topology discovery in heterogeneous IP networks, Proceedings IEEE INFOCOM 2000. Conference on Computer Communications. Nineteenth Annual Joint Conference of the IEEE Computer and Communications Societies (Cat. No.00CH37064), pp.265-274, 2000. ,
DOI : 10.1109/INFCOM.2000.832196
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.123.571
A resource description environment for distributed computing systems, Proceedings. The Eighth International Symposium on High Performance Distributed Computing (Cat. No.99TH8469), pp.279-286, 1999. ,
DOI : 10.1109/HPDC.1999.805307
Modeling Internet topology, IEEE Communications Magazine, vol.35, issue.6, pp.160-163, 1997. ,
DOI : 10.1109/35.587723
Grid Computing: Making the Global Infrastructure a Reality, chapter 33 (Parameter Sweeps on the Grid with APST), 2003. ,
The AppLeS parameter sweep template: User-level middleware for the grid, Proc. of Supercomputing, pp.75-76, 2000. ,
Experiences and results from a new high performance network and application monitoring toolkit, Proc. of the Passive and Active Measurement Workshop (PAM2003), pp.205-217, 2003. ,
Grid information services for distributed resource sharing, Proceedings 10th IEEE International Symposium on High Performance Distributed Computing, pp.181-194, 2001. ,
DOI : 10.1109/HPDC.2001.945188
TopoMon: A monitoring tool for grid network topology, Proc. of the International Conf. on Computational Science number 2330 in LNCS, pp.558-567, 2002. ,
A unified relational approach to grid information services. Informational Draft GWD-GIS-012-1, Global Grid Forum, 2001. ,
A better model for generating test networks, Proceedings of GLOBECOM'96. 1996 IEEE Global Telecommunications Conference, 1996. ,
DOI : 10.1109/GLOCOM.1996.586131
Optimisation of component-based applications within a grid environment, Proceedings of the 2001 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '01, 2001. ,
DOI : 10.1145/582034.582064
ICENI: Optimisation of component applications within a Grid environment, Parallel Computing, vol.28, issue.12, pp.1753-1772, 2002. ,
DOI : 10.1016/S0167-8191(02)00187-4
The applicability of RDF-schema as a syntax for describing grid resource metadata. Informational Draft GWD-GIS-020-1, Global Grid Forum (GGF), 2001. ,
Anatomy of a Resource Management System for HPC Clusters, Zuse-Zentrum für Informationstechnik Berlin (ZIB), 2000. ,
DOI : 10.1142/9789812810182_0001
Constrained component deployment in wide-area networks using AI planning techniques, Proceedings International Parallel and Distributed Processing Symposium, p.3, 2003. ,
DOI : 10.1109/IPDPS.2003.1213075
Deploying CORBA Components on a Computational Grid: General Principles and Early Experiments Using the Globus Toolkit, Proc. of the 2nd International Working Conference on Component Deployment Held in conjunction with the 26th International Conference on Software Engineering, pp.35-49, 2004. ,
DOI : 10.1007/978-3-540-24848-4_3
URL : https://hal.archives-ouvertes.fr/inria-00071435
Design and evaluation of a resource selection framework for grid applications, Proc. of the 11th IEEE Symp. on High Performance Distributed Computing (HPDC-11), pp.63-52, 2002. ,
A hierarchy of network performance characteristics for grid applications and services. Proposed Recommendation Global Grid Forum, Network Measurement Working Group (NMWG), 2004. ,
A resource query interface for network-aware applications, Journal of Cluster Computing, vol.2, issue.2, pp.139-151, 1999. ,
Enabling network measurement portability through a hierarchy of characteristics, Proc. of the 4th International Workshop on Grid Computing (Grid2003), pp.68-75, 2003. ,
Synthesizing Realistic Computational Grids, Proceedings of the 2003 ACM/IEEE conference on Supercomputing, SC '03, 2003. ,
DOI : 10.1145/1048935.1050167
A dynamic matching and scheduling algorithm for heterogeneous computing systems, Proceedings Seventh Heterogeneous Computing Workshop (HCW'98), pp.57-69, 1998. ,
DOI : 10.1109/HCW.1998.666545
A Message-Passing System for Myrinet Networks. reference manual ,
Myrinet Express (MX): A High-Performance, Low-Level, Message-Passing Interface for Myrinet, 2003. ,
The performance of a service for network-aware applications, Proceedings of the SIGMETRICS symposium on Parallel and distributed tools , SPDT '98, pp.81-91, 1998. ,
DOI : 10.1145/281035.281044
A Parallel Corba Component Model for Numerical Code Coupling, Special issue Best Applications Papers from the 3rd International Workshop on Grid Computing, pp.417-429, 2003. ,
DOI : 10.1177/10943420030174006
BIP: A new protocol designed for high performance networking on Myrinet, Proc. of the 1st Workshop on Personal Computer based Networks Of Workstations (PC-NOW'98), pp.472-485, 1998. ,
DOI : 10.1007/3-540-64359-1_721
Matchmaking: distributed resource management for high throughput computing, Proceedings. The Seventh International Symposium on High Performance Distributed Computing (Cat. No.98TB100244), pp.140-146, 1998. ,
DOI : 10.1109/HPDC.1998.709966
Using effective network views to promote distributed application performance, Proc. of the 1999 International Conf. on Parallel and Distributed Processing Techniques and Applications (PDPTA'99), 1999. ,
IP network address translator (NAT) terminology and considerations. Informational RFC 2663, IETF Network Working Group, 1999. ,
Automatic node selection for high performance applications on networks, Proc. of the 7th ACM SIGPLAN Symp. on Principles and Practice of Parallel Programming (PPoPP'99), pp.163-172, 1999. ,
Representing Dynamic Performance Information in Grid Environments with the Network Weather Service, 2nd IEEE/ACM International Symposium on Cluster Computing and the Grid (CCGRID'02), pp.48-56, 2002. ,
DOI : 10.1109/CCGRID.2002.1017111
Component Software: Beyond Object-Oriented Programming ,
Scheduling parallel applications in distributed networks, Cluster Computing, vol.1, issue.1, pp.109-118, 1998. ,
DOI : 10.1023/A:1019073113216
The network weather service: a distributed resource performance forecasting service for metacomputing, Future Generation Computer Systems, vol.15, issue.5-6, pp.5-6757, 1999. ,
DOI : 10.1016/S0167-739X(99)00025-4
Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4 ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt : Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex (France) Unité de recherche, 2004. ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
