Reports
IEEE 802.11 Rate Adaptation: A Practical Approach
Mathieu Lacage 1 Hossein Manshaei 1 Thierry Turletti 1
1 PLANETE - Protocols and applications for the Internet
Inria Grenoble - Rhône-Alpes, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Today, three different physical (PHY) layers for the IEEE 802.11 WLAN are available (802.11a/b/g); they all provide multi-rate capabilities. To achieve high performance under varying conditions, these devices need to adapt their transmission rate dynamically. While this rate adaptation algorithm is a critical component of their performance, only very few algorithms such as Auto Rate Fallback (ARF) or Receiver Based Auto Rate (RBAR) have been published and the implementation challenges associated with these mechanisms have never been publicly discussed. In this paper, we first present the important characteristics of the 802.11 systems that must be taken into account when such algorithms are designed. Specifically, we emphasize the contrast between low latency and high latency systems, and we give examples of actual chipsets that fall in either of the different categories. We propose an Adaptive ARF (AARF) algorithm for low latency systems that improves upon ARF to provide both short-term and long-term adaptation. The new algorithm has very low complexity while obtaining a performance similar to RBAR, which requires incompatible changes to the 802.11 MAC and PHY protocol. Finally, we present a new rate adaptation algorithm designed for high latency systems that has been implemented and evaluated on an AR5212-based device. Experimentation results show a clear performance improvement over the algorithm previously implemented in the AR5212 driver we used.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00070784
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 9:37:24 PM
Last modification on : Friday, February 4, 2022 - 3:19:30 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:54:22 PM
Identifiers
  • HAL Id : inria-00070784, version 1
Collections
Citation
Mathieu Lacage, Hossein Manshaei, Thierry Turletti. IEEE 802.11 Rate Adaptation: A Practical Approach. [Research Report] RR-5208, INRIA. 2004, pp.25. ⟨inria-00070784⟩
Share
Metrics
Record views
345
Files downloads
2233
