GridFTP: Protocol Extension to FTP for the Grid, Grid Forum Internet-Draft, 2001. ,
, Complexity and Approximation, 1999.
Approaches for integrating task and data parallelism, IEEE Concurrency, vol.6, issue.3, pp.74-84, 1998. ,
Scheduling strategies for master-slave tasking on heterogeneous processor platforms, IEEE Trans. Parallel Distributed Systems, vol.15, issue.4, pp.319-330, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00789427
Collection-aware optimum sequencing of operations and closed-form solutions for the distribution of a divisible load on arbitrary processor trees, IEEE Trans. Parallel Distributed Systems, vol.9, issue.5, pp.429-441, 1998. ,
Closed form solutions for bus and tree networks of processors load sharing a divisible job, IEEE Transactions on computers, vol.43, issue.10, pp.1184-1196, 1994. ,
Scheduling divisible loads for star and tree networks: main results and open problems, 2003. ,
Scheduling divisible workloads on heterogeneous platforms, Parallel Computing, vol.29, pp.1121-1152, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00789431
, Grid Computing: Making the Global Infrastructure a Reality, 2003.
Data Networks, 1987. ,
Asymptotically optimal algorithm for job shop scheduling and packet routing, Journal of Algorithms, vol.33, issue.2, pp.296-318, 1999. ,
Optimizing execution of component-based applications using group instances, Future Generation Computer Systems, vol.18, issue.4, pp.435-448, 2002. ,
Efficient scheduling strategies for processing multiple divisible loads on bus networks, J. Parallel and Distributed Computing, vol.62, pp.132-151, 2002. ,
Scheduling Divisible Loads in Parallel and Distributed Systems, 1996. ,
Divisible load theory: a new paradigm for load scheduling in distributed systems, Cluster Computing, vol.6, issue.1, pp.7-17, 2003. ,
Optimal use of mixed task and data parallelism for pipelined computations, J. Parallel and Distributed Computing, vol.61, pp.810-837, 2001. ,
, CDF Analysis Farms (CAF
Modeling Large-Scale Platforms for the Analysis and the Simulation of Scheduling Strategies, Proceedings of the 6th Workshop on Advances in Parallel and Distributed Computational Models (APDCM), 2004. ,
Models and scheduling algorithms for mixed data and task parallel programs, J. Parallel and Distributed Computing, vol.47, pp.168-184, 1997. ,
Lightpath assignment for multifibers WDM optical networks with wavelength translators, IEEE Global Telecommunications Conference, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00072101
, The Grid: Blueprint for a New Computing Infrastructure, 1999.
, Computational Grids: Blueprint for a New Computing Infrastructure. M, 2003.
Computers and Intractability, a Guide to the Theory of NP-Completeness, 1991. ,
, Special issue on Divisible Load Scheduling. Cluster Computing, 2003.
Approximation Algorithms for NP-hard Problems, 1997. ,
Scheduling Distributed Applications: The SimGrid Simulation Framework, Proceedings of the Third IEEE International Symposium on Cluster Computing and the Grid (CCGrid'03), 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00789451
A framework for exploiting task and data parallelism on distributed memory multicomputers, IEEE Trans. Parallel and Distributed Systems, vol.8, issue.11, pp.1098-1116, 1997. ,
Divisible Load Scheduling ,
Processor equivalence for a linear daisy chain of load sharing processors, IEEE Trans. Aerospace and Electronic Systems, vol.29, pp.1216-1221, 1993. ,
Ten reasons to use divisible load theory, IEEE Computer, vol.36, issue.5, pp.63-68, 2003. ,
Executing multiple pipelined data analysis operations in the grid, 2002 ACM/IEEE Supercomputing Conference, 2002. ,
Optimal use of mixed task and data parallelism for pipelined computations, J. Parallel and Distributed Computing, vol.60, pp.297-319, 2000. ,
Data intensive grid scheduling: multiple sources with capacity constraints, PDCS'2003, 15th Int'l Conf. Parallel and Distributed Computing and Systems, 2003. ,
Divisible load scheduling for grid computing, PDCS'2003, 15th Int'l Conf. Parallel and Distributed Computing and Systems. IASTED Press, 2003. INRIA Unité de recherche INRIA ,
, Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex
LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 ,
