Scheduling strategies for master-slave tasking on heterogeneous processor platforms, IEEE Trans. Parallel Distributed Systems, vol.15, issue.4, pp.319-330, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00789427
Collection-aware optimum sequencing of operations and closed-form solutions for the distribution of a divisible load on arbitrary processor trees, IEEE Trans. Parallel Distributed Systems, vol.9, issue.5, pp.429-441, 1998. ,
Gang scheduling with memory considerations, 14th International Parallel and Distributed Processing Symposium (IPDPS'2000), 2000. ,
A proposal for a heterogeneous cluster ScaLAPACK (dense linear solvers), IEEE Trans. Computers, vol.50, issue.10, pp.1052-1070, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00808287
Bandwidth-centric allocation of independent tasks on heterogeneous platforms, International Parallel and Distributed Processing Symposium (IPDPS'2002), 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00072412
Assessing the impact and limits of steady-state scheduling for mixed task and data parallelism on heterogeneous platforms, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00789444
A polynomial-time algorithm for allocating independent tasks on heterogeneous fork-graphs, ISCIS XVII, Seventeenth International Symposium On Computer and Information Sciences, pp.115-119, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00807403
Scheduling divisible workloads on heterogeneous platforms, Parallel Computing, vol.29, pp.1121-1152, 2003. ,
DOI : 10.1016/s0167-8191(03)00095-4
URL : https://hal.archives-ouvertes.fr/hal-00789431
Optimal Sequencing and Arrangement in Single-Level Tree Networks with Communication Delays, IEEE transactions on parallel and distributed systems, vol.5, 1994. ,
Scheduling Divisible Loads in Parallel and Distributed Systems, 1996. ,
A new paradigm for load scheduling in distributed systems, Cluster Computing, vol.6, issue.1, pp.7-18, 2003. ,
Autonomous protocols for bandwidthcentric scheduling of independent-task applications, International Parallel and Distributed Processing Symposium IPDPS, 2003. ,
Heuristics for Scheduling Parameter Sweep Applications in Grid Environments, Ninth Heterogeneous Computing Workshop, pp.349-363, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00748942
Computer and job-shop scheduling theory, 1976. ,
Adaptive scheduling under memory pressure on multiprogrammed clusters, Proceedings of the IEEE Symposium on Cluster Computing and the Grid (CCGrid'02), 2002. ,
Divisible Load Scheduling in Systems with Limited Memory, Cluster Computing, vol.6, issue.1, pp.19-29, 2003. ,
Master-slave tasking on heterogeneous processors, International Parallel and Distributed Processing Symposium IPDPS'2003, 2003. ,
DOI : 10.1109/ipdps.2003.1213103
URL : https://hal.archives-ouvertes.fr/inria-00001081
Complexity of master-slave tasking on heterogeneous trees, Special issue on the Dagstuhl meeting on Scheduling for Computing and Manufacturing systems, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00001076
Computers and Intractability, a Guide to the Theory of NP-Completeness, 1991. ,
, Special issue on Divisible Load Scheduling. Cluster Computing, 2003.
An enabling framework for masterworker applications on the computational grid, Ninth IEEE International Symposium on High Performance Distributed Computing (HPDC'00), 2000. ,
Cyclic scheduling on parallel processors: an overview, Scheduling Theory and its Applications, pp.193-226, 1994. ,
Adaptive scheduling for master-worker applications on the computational grid, Grid Computing -GRID 2000, pp.214-227, 1971. ,
Dynamic autonomous scheduling on Heterogeneous Systems, 2003. ,
Dynamic matching and scheduling of a class of independent tasks onto heterogeneous computing systems, Eight Heterogeneous Computing Workshop, pp.30-44, 1999. ,
Divisible Load Scheduling ,
Ten reasons to use divisible load theory, IEEE Computer, vol.36, issue.5, pp.63-68, 2003. ,
Master/slave computing on the grid, Heterogeneous Computing Workshop HCW'00, 2000. ,
Scheduling multi-component applications in heterogeneous wide-area networks, Heterogeneous Computing Workshop HCW'00, 2000. ,
, Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex
LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 ,
