Wireless sensor " device provides remote sensing in an efficient way. No physical connection is necessary. Any off-the-shelf Bluetooth dongle connected to a PC allows interfacing this device ,
Micro Electro Mechanical Systems) dual axis inclination sensor ,
? +/-60 degrees dual axis inclination measurement, ? Resolution better than 0.5 degree arc, ? Bandwidth better than 100 Hertz, ? Distance between PC and device up to 10 meters ,
