A fundamental relationship between bilateral filtering, adaptive smoothing , and the nonlinear diffusion equation Infra-red sequence. (a) one image of the original sequence, (b) the corresponding image of the denoised sequence with the non-local filter applied with a patch of size 5×5 and the bandwidth equal to four times the noise standard deviation, (c) denoised image with the proposed motion compensated filter, IEEE Trans. on Pattern Analysis and Ma- Irisa Figure, vol.7 ,
DOI : 10.1109/tpami.2002.1008390
Robust anisotropic diffusion, IEEE Transactions on Image Processing, vol.7, issue.3, pp.421-432, 1998. ,
DOI : 10.1109/83.661192
Adaptive spatio-temporal restoration for 4d fluoresence microscopic imaging, Proc. of 8th International Conference on Medical Image Computing and Computer Assisted Intervention, 2005. ,
Noise reduction filters for dynamic image sequences: a review, Proc. of the IEEE, pp.1272-1291, 1995. ,
DOI : 10.1109/5.406412
Denoising image sequences does not require motion estimation, Proceedings. IEEE Conference on Advanced Video and Signal Based Surveillance, 2005., 2005. ,
DOI : 10.1109/AVSS.2005.1577245
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.131.6394
A review of image denoising algorithms, with a new one. Multiscale Modeling and Simulation: A, SIAM Interdisciplinary Journal, vol.4, issue.2, pp.490-530, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00271141
Adaptive spatio-temporal filtering for video-denoising, Proc. of IEEE Int. Conf. on Image Processing, pp.965-968, 2004. ,
Region Filling and Object Removal by Exemplar-Based Image Inpainting, IEEE Transactions on Image Processing, vol.13, issue.9, pp.1200-1212, 2004. ,
DOI : 10.1109/TIP.2004.833105
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.140.9434
Spatio-temporal Wiener filtering of image sequences using a parametric motion model, Proceedings 2000 International Conference on Image Processing (Cat. No.00CH37101), pp.208-211, 2000. ,
DOI : 10.1109/ICIP.2000.900931
Video denoising by combining Kalman and Wiener estimates, Proceedings 1999 International Conference on Image Processing (Cat. 99CH36348) ,
DOI : 10.1109/ICIP.1999.819568
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.390.936
Texture synthesis by non-parametric sampling, Proceedings of the Seventh IEEE International Conference on Computer Vision, pp.1033-1038, 1999. ,
DOI : 10.1109/ICCV.1999.790383
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.117.2805
Spatio-temporal pointwise adaptive denoising in video: 3d non parametric approach, Proc. of the 1st International Workshop on Video Processing and Quality Metrics for Consumer Electronics, VPQM'2005, 2005. ,
Video denoising using oriented complex wavelet transforms, Proc. of the IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.949-952, 2004. ,
Residual variance and residual pattern in nonlinear regression, Biometrika, vol.73, issue.3, pp.625-633, 1986. ,
DOI : 10.1093/biomet/73.3.625
Adaptive window size image denoising based on intersection of confidence intervals (ICI) rule, Journal of Mathematical Imaging and Vision, vol.16, issue.3, pp.223-235, 2002. ,
DOI : 10.1023/A:1020329726980
An Adaptive Window Approach for Image Smoothing and Structures Preserving, Proc. of 8th Eur. Conf. on Computer Vision, pp.132-144, 2004. ,
DOI : 10.1007/978-3-540-24672-5_11
Unsupervised Patch-Based Image Regularization and Representation, Proc. of 9th Eur. Conf. on Computer Vision, 2006. ,
DOI : 10.1007/11744085_43
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.80.7925
Spatio-temporal video filtering algorithm based on 3-D anisotropic diffusion equation, Proc. of IEEE Int. Conf. on Image Processing, pp.447-450, 1998. ,
Asymptotically minimax adaptive estimation 1: upper bounds, SIAM Journal Theory of Probability and Application, vol.36, issue.4, pp.654-659, 1991. ,
Fast image and video denoising via nonlocal means of similar neighborhoods, IEEE Signal Processing Letters, vol.12, issue.12, pp.839-842, 2005. ,
DOI : 10.1109/LSP.2005.859509
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.103.1732
The DUDE framework for continuous tone image denoising, IEEE International Conference on Image Processing 2005, pp.345-348, 2005. ,
DOI : 10.1109/ICIP.2005.1530399
Robust Multiresolution Estimation of Parametric Motion Models, Journal of Visual Communication and Image Representation, vol.6, issue.4, pp.348-365, 1995. ,
DOI : 10.1006/jvci.1995.1029
Adaptive weights smoothing with applications to image restoration, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.62, issue.2, pp.335-354, 2000. ,
DOI : 10.1111/1467-9868.00235
Adaptive wavelet restoration of noisy video sequences, 2004 International Conference on Image Processing, 2004. ICIP '04., pp.957-960, 2004. ,
DOI : 10.1109/ICIP.2004.1419459
Nonlinear total variation based noise removal algorithms, Physica D: Nonlinear Phenomena, vol.60, issue.1-4, pp.259-268, 1992. ,
DOI : 10.1016/0167-2789(92)90242-F
Space-time video completion, IEEE Conference on Computer Vision and Pattern Recognition, pp.120-127, 2004. ,
DOI : 10.1109/cvpr.2004.1315022
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.515.9302
Image information restoration based on long-range correlation, IEEE Transactions on Circuits and Systems for Video Technology, vol.12, issue.5, pp.331-341, 2002. ,
DOI : 10.1109/TCSVT.2002.1003472
Motion- and detail-adaptive denoising of video, Image Processing: Algorithms and Systems III, pp.403-412, 2004. ,
DOI : 10.1117/12.520847
