New interface
Reports (Research report)
Model of concurrent MPI communications over SMP clusters
Maxime Martinasso 1 Jean-François Méhaut 1
1 MESCAL - Middleware efficiently scalable
ID-IMAG - Informatique et Distribution, Inria Grenoble - Rhône-Alpes
Abstract : SMP clusters are one of the most common HPC platform used by scientific applications. The nodes of SMP cluster contain several computing elements. Scientific applications may be executed over a large number of such nodes introducing complex communication behaviors. Using for instance MPI, communications on a same node with a common interval time create concurrent accesses to resources of nodes. On SMP nodes, concurrent access implies resource sharing depending on the underlying network architecture and the MPI implementation used. This paper presents a model to predict communication times of simultaneous MPI communications over SMP clusters. This model considers the concurrency over resources of nodes and network predicting accurately communication time for many communications in conflict.
Document type :
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071352
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 4:48:48 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:51 AM
Long-term archiving on: : Sunday, April 4, 2010 - 8:13:50 PM
Identifiers
  • HAL Id : inria-00071352, version 1
Citation
Maxime Martinasso, Jean-François Méhaut. Model of concurrent MPI communications over SMP clusters. [Research Report] RR-5910, INRIA. 2006. ⟨inria-00071352⟩
Share
Metrics
Record views
138
Files downloads
185
