Newton methods for nonsmooth convex minimization: connections among U-Lagrangian, Riemannian Newton and SQP methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Programming Année : 2005
This paper studies Newton-type methods for minimization of partly smooth convex functions. Sequential Newton methods are provided using local parameterizations obtained from U-Lagrangian theory and from Riemannian geometry. The Hessian based on the U-Lagrangian depends on the selection of a dual parameter g; by revealing the connection to Riemannian geometry, a natural choice of g emerges for which the two Newton directions become identical. This choice of g is also shown to be related to the least-squares multiplier estimate from a sequential quadratic programming (SQP) approach, and with this multiplier, SQP gives the same search direction as the Newton methods.
MM05.pdf (261.16 Ko) Télécharger le fichier
inria-00071403 , version 1 (23-05-2006)
inria-00071403 , version 2 (25-03-2013)
Scott A. Miller, Jérôme Malick. Newton methods for nonsmooth convex minimization: connections among U-Lagrangian, Riemannian Newton and SQP methods. Mathematical Programming, 2005, 104, ⟨10.1007/s10107-005-0631-2⟩. ⟨inria-00071403v2⟩
Collections
INRIA INRIA2
131 Consultations
576 Téléchargements
