Adaptive mesh generation for global diffuse illumination, Computer Graphics (SIGGRAPH '90 Proceedings), pp.155-164, 1990. ,
An analytic approach to illumination with area light sources, 1991. ,
Lines in space: Combinatorics and algorithms, Algorithmica, vol.6, issue.5, pp.382-393, 1990. ,
DOI : 10.1007/BF01955043
Near real-time shadow generation using bsp trees, Computer Graphics (SIGGRAPH '89 Proceedings), pp.99-106, 1989. ,
A progressive refinement approach to fast radiosity image generation, Computer Graphics (SIG- GRAPH '88 Proceedings), pp.75-84, 1988. ,
The hemi-cube, ACM SIGGRAPH Computer Graphics, vol.19, issue.3, pp.31-40, 1985. ,
DOI : 10.1145/325165.325171
Shadow algorithms for computer graphics, Computer Graphics (SIGGRAPH '77 Proceedings), pp.242-248, 1977. ,
Structured Sampling and Reconstruction of Illumination for Image Synthesis, 1994. ,
A fast shadow algorithm for area light sources using backprojection, Proceedings of the 21st annual conference on Computer graphics and interactive techniques , SIGGRAPH '94, 1994. ,
DOI : 10.1145/192161.192207
URL : https://hal.archives-ouvertes.fr/inria-00510136
Algorithms in Computational Geometry, 1987. ,
Efficiently computing and representing aspect graphs of polyhedral objects, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.6, pp.542-551, 1991. ,
DOI : 10.1109/34.87341
Computing the aspect graph for line drawings of polyhedral objects, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.12, issue.2, pp.113-122, 1990. ,
DOI : 10.1109/34.44399
A rapid hierarchical radiosity algorithm, Computer Graphics (SIG- GRAPH '91 Proceedings), pp.197-206, 1991. ,
Discontinuity meshing for radiosity, Third Eurographics Workshop on Rendering, pp.203-215, 1992. ,
Discontinuity meshing for accurate radiosity, IEEE Computer Graphics and Applications, vol.12, issue.6, pp.25-39, 1992. ,
DOI : 10.1109/38.163622
Combining hierarchical radiosity and discontinuity meshing, Proceedings of the 20th annual conference on Computer graphics and interactive techniques , SIGGRAPH '93, pp.199-208, 1993. ,
DOI : 10.1145/166117.166143
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.19.7331
Worst-case optimal hidden-surface removal, ACM Transactions on Graphics, vol.6, issue.1, pp.19-28, 1987. ,
DOI : 10.1145/27625.27627
Half-tone representation of 3-d objects illuminated by area sources or polyhedron sources. COMPSAC'83, Proc. IEEE 7th Intl. Conf. Soft. and Appl. Conf, pp.237-242, 1983. ,
A treatise on the Analytical Geometry of Three Dimensions. Longmans, Green and Co, 20] Arthur Scherk. personal communications. [21] Duncan M. Y. Sommerville. Analytical Geometry in three dimensions, 1912. ,
An output sensitive algorithm for the computation of shadow boundaries, Canadian Conference on Computational Geometry, pp.291-296, 1993. ,
Oriented projective geometry, Proceedings of the third annual symposium on Computational geometry , SCG '87, 1988. ,
DOI : 10.1145/41958.41966
Computing the antipenumbra of polyhedral holes, Computer Graphics (SIGGRAPH Procedings), 1992. ,
Visibility Computations in Densely Occluded Polyhedral Environments, 1993. ,
Projective Geometry, 1938. ,
Arts : Accelerated ray-tracing system, IEEE Computer Graphics and Applications, pp.16-26, 1986. ,
Efficient image-based methods for rendering soft shadows, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, pp.375-384, 2000. ,
DOI : 10.1145/344779.344954
The irradiance Jacobian for partially occluded polyhedral sources, ACM SIG- GRAPH ', vol.94, pp.343-350, 1994. ,
A fast voxel traversal algorithm for ray tracing, pp.3-10, 1987. ,
Radiance interpolants for accelerated bounded-error ray tracing, ACM Transactions on Graphics, vol.18, issue.3, pp.213-256, 1999. ,
DOI : 10.1145/336414.336417
A subdivision algorithm for computer display of curved surfaces, 1974. ,
Adaptive mesh generation for global diffuse illumination, Proc. SIGGRAPH '90), pp.24-155, 1990. ,
Fast object-precision shadow generation for areal light sources using BSP trees, Symposium on Interactive 3D Graphics), pp.21-30, 1992. ,
DOI : 10.1145/147156.147159
Shadow algorithms for computer graphics, Computer Graphics (Proc. SIG- GRAPH, vol.77, issue.11 2, pp.242-248, 1977. ,
The 3D visibility complex, ACM Transactions on Graphics, vol.21, issue.2, 2002. ,
DOI : 10.1145/508357.508362
URL : https://hal.archives-ouvertes.fr/inria-00606717
A fast shadow algorithm for area light sources using backprojection, Proceedings of the 21st annual conference on Computer graphics and interactive techniques , SIGGRAPH '94, pp.223-230, 1994. ,
Predicates and constructions for visibility problems , manuscrit, 2001. ,
Interval arithmetic and recursive subdivision for implicit functions and constructive solid geometry, Proc. SIGGRAPH'92), pp.131-138, 1992. ,
Practiral and robust stenciled shadow volumes for hardware accelerated rendering ,
Hierarchical Z-buffer visibility, Proceedings of the 20th annual conference on Computer graphics and interactive techniques , SIGGRAPH '93, 1993. ,
DOI : 10.1145/166117.166147
Space subdivision for fast ray tracing, IEEE Computer Graphics and Applications, vol.4, issue.10, pp.15-22, 1984. ,
DOI : 10.1109/MCG.1984.6429331
Computing the aspect graph for the line drawings of polyhedral objects, IEEE Trans. Pattern Analysis and Machine Intelligence, vol.12, issue.2, 1990. ,
Automatic creation of object hierarchies for raytracing, IEEE Computer Graphics and Applications, pp.14-20, 1987. ,
Shaft culling for efficient ray-traced radiosity, Photorealistic Rendering in Comp, Proc. 2nd EG Workshop on Rendering, pp.122-138, 1991. ,
Simulating global illumination using adaptive meshing, 1991. ,
Adaptive voxel subdivision for ray tracing, Proceedings Graphic's Interface '89, pp.164-172, 1989. ,
The rendering equation Computer Graphics, SIGGRAPH '86 Proceedings ) Computer Graphics Proceedings , Annual Conference Series, pp.143-150, 1986. ,
The internal representation of solid shape with respect to vision, Biological Cybernetics, vol.42, issue.4, pp.211-216, 1979. ,
DOI : 10.1007/BF00337644
Guaranteed Occlusion and Visibility in Cluster Hierarchical Radiosity, Proc. Eurographics Workshop on Rendering, pp.89-100, 2000. ,
DOI : 10.1007/978-3-7091-6303-0_9
THE VISIBILITY COMPLEX, International Journal of Computational Geometry & Applications, vol.06, issue.03, pp.279-308, 1996. ,
DOI : 10.1142/S0218195996000204
Topologically sweeping the visibility complex of polygonal scenes, Proceedings of the eleventh annual symposium on Computational geometry , SCG '95, pp.436-437, 1995. ,
DOI : 10.1145/220279.220339
Perspective shadow maps, Proceedings of ACM SIGGRAPH Annual Conference Series, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00606740
Fast computation of shadow boundaries using spatial coherence and backprojections, Proceedings of the 21st annual conference on Computer graphics and interactive techniques , SIGGRAPH '94, pp.231-238, 1994. ,
DOI : 10.1145/192161.192210
Epsilon geometry: building robust algorithms from imprecise computations, Proceedings of the fifth annual symposium on Computational geometry , SCG '89, 1989. ,
DOI : 10.1145/73833.73857
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.144.3416
Computing the approximative visibility map, with applications to form factor and discontinuity meshing, 1998. ,
Interval analysis for computer graphics, Proc. SIG- GRAPH'92), pp.121-130, 1992. ,
Exact radiosity reconstruction and shadow computation using vertex tracing, Proceedings of 11th Eurographics Workshop on Rendering, 2000. ,
Fast calculation of soft shadow textures using convolution, Proceedings of the 25th annual conference on Computer graphics and interactive techniques , SIGGRAPH '98, pp.321-332, 1998. ,
DOI : 10.1145/280814.280927
URL : https://hal.archives-ouvertes.fr/inria-00510082
Computing the antipenumbra of an area light source, Proceedings of SIGGRAPH '92, Computer Graphics Proceedings, Annual Conference Series, ACM SIGGRAPH, pp.139-148, 1992. ,
Visibility preprocessing for interactive walkthrough, ACM SIGGRAPH '91, pp.61-69, 1991. ,
Metropolis light transport, Proceedings of the 24th annual conference on Computer graphics and interactive techniques , SIGGRAPH '97, pp.65-76, 1997. ,
DOI : 10.1145/258734.258775
Hidden surface removal using polygon area sorting, Computer Graphics (Proc. SIGGRAPH, vol.77, issue.11 2, pp.214-222, 1977. ,
DOI : 10.1145/965141.563896
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.137.7161
Casting curved shadows on curved surfaces, Proceedings of SIG- GRAPH '78, pp.270-274, 1978. ,
A survey of shadow algorithms, IEEE Computer Graphics and Applications, vol.10, issue.6, pp.13-32, 1990. ,
DOI : 10.1109/38.62693
Visibility culling using hierarchical occlusion maps, Proceedings of the 24th annual conference on Computer graphics and interactive techniques , SIGGRAPH '97, 1997. ,
DOI : 10.1145/258734.258781
route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, 2004. ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
