Blind Adaptive Channel Estimationin OFDM Systems
We consider the problem of blind channel estimation in zero padding OFDM systems. For the first time, blind adaptive algorithms are proposed that identify the impulse response of the multipath channel. In particular, we develop RLS and LMS schemes that exhibit rapid convergence combined with low computational complexity and numerical stability. Both versions are obtained by properly modifying the orthogonal iteration method used in Numerical Analysis for the computation of singular vectors. With a number of simulation experiments we demonstrate the satisfactory performance of our adaptive schemes under diverse signaling conditions.
