A reliable multicast protocol for distributed mobile systems: design and evaluation, IEEE Trans. Parallel Distributed Systems, vol.12, issue.10, pp.1009-1022, 2001. ,
, Complexity and Approximation, 1999.
Efficient collective communication on heterogeneous networks of workstations, Proceedings of the 27th International Conference on Parallel Processing (ICPP'98), 1998. ,
Communication modeling of heterogeneous networks of workstations for performance characterization of collective operations, HCW'99, the 8th Heterogeneous Computing Workshop, pp.125-133, 1999. ,
Optimizing the steady-state throughput of broadcasts on heterogeneous platforms heterogeneous platforms, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00071712
Pipelining broadcasts on heterogeneous platforms, International Parallel and Distributed Processing Symposium IPDPS, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00358950
Adaptive communication algorithms for distributed heterogeneous systems, Journal of Parallel and Distributed Computing, vol.59, issue.2, pp.252-279, 1999. ,
Efficient collective communication in distributed heterogeneous systems, ICDCS'99 19th International Conference on Distributed Computing Systems, pp.15-24, 1999. ,
Modeling internet topology, IEEE Communications Magazine, vol.35, issue.6, pp.160-163, 1997. ,
Optimized broadcasting and multicasting protocols in cut-through routed networks, IEEE Trans. Parallel Distributed Systems, vol.9, issue.8, pp.788-802, 1998. ,
, Synthesis of Parallel Algorithms, 1993.
Computers and Intractability, a Guide to the Theory of NP-Completeness, 1991. ,
, Matrix computations. Johns Hopkins, 1989.
A reliable multicast algorithm for mobile ad hoc networks, ICDCS'02, 22nd Int. Conf. Distributed Computing Systems, pp.563-570, 2002. ,
Scheduling in broadcast networks, Networks, vol.32, issue.14, pp.233-253, 1998. ,
Cyclic scheduling on parallel processors: an overview, Scheduling Theory and its Applications, pp.193-226, 1994. ,
Scheduling algorithms for efficient gather operations in distributed heterogeneous systems, 2000 International Conference on Parallel Processing, 2000. ,
Reducibility among combinatorial problems, Complexity of Computer Computations, pp.85-103, 1972. ,
A fast algorithm for steiner trees, Acta Informatica, vol.15, pp.141-145, 1981. ,
Routing to multiple destinations in computer networks, IEEE Trans. Communications, vol.31, issue.3, pp.343-351, 1983. ,
Optimizing the steady-state throughput of scatter and reduce operations on heterogeneous platforms, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00789447
Optimizing the steady-state throughput of scatter and reduce operations on heterogeneous platforms, APDCM'2004, 6th Workshop on Advances in Parallel and Distributed Computational Models, 2004. ,
On multicast algorithms for heterogeneous networks of workstations, Journal of Parallel and Distributed Computing, vol.61, issue.11, pp.1665-1679, 2001. ,
Multicast communication in multicomputer networks, IEEE Trans. Parallel Distributed Systems, vol.4, issue.10, pp.1105-1117, 1993. ,
Broadcast scheduling optimization for heterogeneous cluster systems, Journal of Algorithms, vol.42, issue.1, pp.135-152, 2002. ,
Broadcast scheduling optimization for heterogeneous cluster systems, SPAA'2000, 12th Annual ACM Symposium on Parallel Algorithms and Architectures, pp.129-136, 2000. ,
Reduction optimization in heterogeneous cluster environments, 14th International Parallel and Distributed Processing Symposium (IPDPS'2000), 2000. ,
Eco: Efficient collective operations for communication on heterogeneous networks, 10th International Parallel and Distributed Processing Symposium (IPDPS'96), 1996. ,
Efficient gather operation in heterogeneous cluster systems, Proceedings of the 16th International Symposium on High Performance Computing Systems and Applications (HPCS'02), 2002. ,
Multicast tree generation in networks with asymmetric links, IEEE/ ACM Transactions on Networking, vol.4, issue.4, pp.558-568, 1996. ,
Optimal multicast communication in wormhole-routed torus networks, IEEE Trans. Parallel Distributed Systems, vol.6, issue.10, pp.1029-1042, 1995. ,
Combinatorial Optimization: Polyhedra and Efficiency, Algorithms and Combinatorics, vol.24, 2003. ,
Theory of Linear and Integer Programming, 1986. ,
Architectural support for efficient multicasting in irregular networks, IEEE Trans. Parallel Distributed Systems, vol.12, issue.5, pp.489-513, 2001. ,
An approximate solution for the steiner tree problem in graphs, Intl. J. Math Educ. in Sci. and Technol, vol.14, issue.1, pp.15-23, 1983. ,
Energy-aware wireless networking with directional antennas: the case of session-based broadcasting and multicasting, IEEE Trans. Mobile Computing, vol.1, issue.3, pp.176-191, 2002. ,
Steiner problem in networks: a survey, Networks, vol.17, issue.2, pp.129-167, 1987. ,
Nonblocking WDM multicast switching networks, IEEE Trans. Parallel Distributed Systems, vol.11, issue.12, pp.1274-1287, 2000. ,
, Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex
LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 ,
