Ad Hoc Mobility Notification in Wireless Infrastructure Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Hybrid networks composed of a wireless infrastructure network providing Internet access to an underlying ad hoc network are more and more attractive due to their low installation cost. In these all-wireless environments, performance is a key issue as radio bandwidth is scarce. Handoffs management is particularly important as these networks are likely to be highly mobile. Mobility notification should therefore be optimized in order to limit signaling overhead while keeping a good reactivity against terminals mobility. This article presents and studies by simulation different level optimizations applied to a modified Cellular IP protocol.
Autre [cs.OH]
RR-5113.pdf (3.29 Mo) Télécharger le fichier
inria-00071469 , version 1 (23-05-2006)
  • HAL Id : inria-00071469 , version 1
Guillaume Chelius, Claude Chaudet, Natalie Whitlock. Ad Hoc Mobility Notification in Wireless Infrastructure Networks. [Research Report] RR-5113, INRIA. 2004. ⟨inria-00071469⟩
58 Consultations
158 Téléchargements
