HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
A Newton method using exact jacobians for solving fluid-structure coupling
Abstract : This report aims at introducing a partitioned Newton based method for solving nonlinear coupled systems arising in the numerical approximation of fluid-structure interaction problems. We provide a method which characteristic lies in the use of exact cross jacobians evaluation involving the shape derivative of the fluid state with respect to solid motion perturbations. Numerical tests based on an implementation inside a 3D fluid-structure interaction code show how the exactness of the cross jacobians computation guarantee the overall convergence of the Newton's loop.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00071498
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, May 23, 2006 - 5:46:44 PM
Last modification on : Thursday, January 20, 2022 - 5:32:09 PM
Long-term archiving on: : Sunday, April 4, 2010 - 10:19:59 PM
Identifiers
  • HAL Id : inria-00071498, version 1
Citation
Miguel Angel Fernández, Marwan Moubachir. A Newton method using exact jacobians for solving fluid-structure coupling. [Research Report] RR-5085, INRIA. 2004. ⟨inria-00071498⟩
Share
Metrics
Record views
122
Files downloads
1051
