A fast algorithm for the two dimensional HJB equation of stochastic control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
This paper analyses the implementation of the generalized finite differences method for the HJB equation of stochastic control, introduced by two of the authors in . The computation of coefficients needs to solve at each point of the grid (and for each control) a linear programming problem. We show here that, for two dimensional problems, this linear programming problem can be solved in O(p) operations, where p is the size of the stencil. The method is based on a walk on the Stern-Brocot tree, and on the related filling of the set of positive semidefinite matrices of size two.
RR-5078.pdf (318.54 Ko) Télécharger le fichier
inria-00071505 , version 1 (23-05-2006)
  • HAL Id : inria-00071505 , version 1
J. Frederic Bonnans, Elisabeth Ottenwaelter, Hasnaa Zidani. A fast algorithm for the two dimensional HJB equation of stochastic control. [Research Report] RR-5078, INRIA. 2004. ⟨inria-00071505⟩
109 Consultations
728 Téléchargements
