Applications = Components + Scripts -A Tour of Piccola, Software Architectures and Component Technology, pp.261-292, 2001. ,
A brief summary of VSPEC, World Congress on Formal Methods, pp.1068-1086, 1999. ,
DOI : 10.1007/3-540-48118-4_7
A formal basis for architectural connection, ACM Transactions on Software Engineering and Methodology, vol.6, issue.3, pp.213-249, 1997. ,
DOI : 10.1145/258077.258078
URL : https://hal.archives-ouvertes.fr/hal-00444067
Integrating the Synchronous Paradigm into UML: Application to Control-Dominated Systems, Proceedings of 5th International «UML» Conference, number 2460, 2002. ,
DOI : 10.1007/3-540-45800-X_15
The Foundations of Esterel, Proof, Language, and Interaction, Essays in Honor of Robin Milner, 2000. ,
Transformational design and implementation of a new efficient solution to the ready simulation problem, Science of Computer Programming, vol.24, issue.3, pp.189-220, 1996. ,
DOI : 10.1016/0167-6423(95)00003-B
Object-Oriented Frameworks: Problems & Experiences Building Application Frameworks: Object Oriented Foundations of Framework Design, 1999. ,
6th Workshop on Component-Oriented Programming, Workshop Reader LNCS, 1964. ,
DOI : 10.1007/3-540-47853-1_8
Compiler and Tool Support for Debugging Object Protocols, Proceedings of the 8th ACM SIGSOFT International Symposium on Foundations of Software Engineering, pp.50-59, 2000. ,
Compatibility and inheritance in software architectures, Science of Computer Programming, vol.41, issue.2, pp.105-138, 2001. ,
DOI : 10.1016/S0167-6423(01)00002-8
Simplifying an Extensible Class Library Interface with OpenC++, OOPSLA'98, Worshop on Reflective Programming in C++ and Java, 1998. ,
Synchronous and Bidirectional Component Interfaces, Proceeeding CAV, number 2404 in LNCS, pp.214-227, 2002. ,
DOI : 10.1007/3-540-45657-0_34
A metaobject protocol for C++, OOPSLA'95, pp.285-299, 1995. ,
DOI : 10.1145/217839.217868
NuSMV 2: An OpenSource Tool for Symbolic Model Checking, Proceeeding CAV, number 2404 in LNCS, pp.359-364, 2002. ,
DOI : 10.1007/3-540-45657-0_29
A Basic Model of Typed Components, LNCS, vol.1850, pp.108-128, 2000. ,
Pilotage de programmes pour le traitement d'images médicales, 1999. ,
Generative Programming, 2001. ,
DOI : 10.1007/3-540-36208-8_2
CORBA Component Model Joint Revised Submission, 1999. ,
Expert Systems : Principles and Case Studies, 1989. ,
Design Patterns: Elements of Reusable Object-Oriented Software, 1995. ,
Synchronous Observers and the Verification of Reactive Systems, Third Int. Conf. on Algebraic Methodology and Software Technology, AMAST'93 Workshops in Computing, 1993. ,
DOI : 10.1007/978-1-4471-3227-1_8
On object systems and behavioral inheritance, IEEE Transactions on Software Engineering, vol.28, issue.9, 2002. ,
DOI : 10.1109/TSE.2002.1033228
On the development of reactive systems Advanced Study institute on Logics and Models for Verification and Specification of Concurrent Systems, In NATO, 1985. ,
Computing simulations on finite and infinite graphs, Proceedings of IEEE 36th Annual Foundations of Computer Science, pp.453-462, 1995. ,
DOI : 10.1109/SFCS.1995.492576
HYTECH: a??model checker for hybrid systems, International Journal on Software Tools for Technology Transfer, vol.1, issue.1-2, pp.110-122, 1997. ,
DOI : 10.1007/s100090050008
The model checker SPIN, IEEE Transactions on Software Engineering, vol.23, issue.5, pp.279-295, 1997. ,
DOI : 10.1109/32.588521
Frameworks = (Components + Patterns), CACM, vol.10, issue.40, pp.39-42, 1997. ,
DOI : 10.1145/262793.262799
Designing Reusable Classes, Journal of Object-Oriented Programming, vol.1, issue.2, pp.22-35, 1988. ,
The Art of the Meta-Object Protocol, 1991. ,
Aspect-oriented programming, p.97, 1997. ,
A behavioral notion of subtyping, ACM Transactions on Programming Languages and Systems, vol.16, issue.6, pp.1811-1841, 1994. ,
DOI : 10.1145/197320.197383
The SMV Model Checker Available from, 2001. ,
An experiment in program composition and proof. Formal Methods in System Design, pp.7-21, 2002. ,
Operational and compositional semantics of synchronous automaton compositions, LNCS: Concur, vol.630, 1992. ,
DOI : 10.1007/BFb0084815
Towards a Dynamic CORBA Component Platform, 2nd International Symposium on Distributed Object Applications, 2000. ,
Object-Oriented Software Construction, 1988. ,
An algebraic definition of simulation between programs, Proc. Int. Joint Conf. Artificial Intelligence, pp.481-489, 1971. ,
Réutilisation et générateurs de systèmes à base de connaissances : le framework BLOCKS, TSI, vol.20, issue.4, pp.529-553, 2001. ,
BLOCKS, a Component Framework with Checking Facilities for Knowledge-Based Systems. Informatica, Special Issue on Component Based Software Development, pp.501-507, 2001. ,
Object-Oriented Software Composition, chapter Regular Types for Active Objects, pp.99-121, 1995. ,
Behavior protocols for software components, IEEE Transactions on Software Engineering, vol.28, issue.11, 2002. ,
DOI : 10.1109/TSE.2002.1049404
Analysis of Component-Based Systems -An Automated Theorem Proving Approach, Specification and Verification of Component-Based Systems (SAVCBS'2001) Workshop at OOPSLA'2001, 2001. ,
The Unified Modeling Language Reference Manual, 1999. ,
A Component Oriented Notation for Behavioral Specification and Validation, Specification and Verification of Component-Based Systems (SAVCBS'2001) Workshop at OOPSLA'2001, 2001. ,
Using UML for modeling complex real-time systems, 1998. ,
DOI : 10.1007/BFb0057795
Component Software -Beyond Object-Oriented Programming, 1998. ,
Component-Oriented Programming Workshop, ECOOP'99 Workshop Reader, 1999. ,
Simulation Revisited, Proceedings TACAS 2001, number 2031 in LNCS, pp.480-495, 2001. ,
DOI : 10.1007/3-540-45319-9_33
Protocol specifications and component adaptors, ACM Transactions on Programming Languages and Systems, vol.19, issue.2, pp.292-333, 1997. ,
DOI : 10.1145/244795.244801
route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, 2004. ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
