S. Coquillart, Extended free form deformation: a sculptural tool for 3D geometric modelling, pp.187-196, 1990.
Y. Berard, A: Algorithmes génétiques perturbés par le gradient
C. Darwin, On the origin of species by means of natural selection, p.1859
DOI : 10.5962/bhl.title.24329
V. Dolean and S. Lanteri, A domain decomposition approach to finite volume solutions of the Euler equations on unstructured triangular meshes, International Journal for Numerical Methods in Fluids, vol.22, issue.6, 1999.
DOI : 10.1002/fld.184
R. Duvigneau, ContributionàContributionà l'optimisation de forme pour desécoulementsàdesécoulementsdesécoulementsà forts nombres de Reynolds autour de géométries complexes, Thèse de Doctorat, 2002.
C. Farhat, C. Degand, B. Koobus, and M. Lesoinne, Torsional springs for two-dimensional dynamic unstructured fluid meshes, Computer Methods in Applied Mechanics and Engineering, vol.163, issue.1-4, pp.231-245, 1998.
DOI : 10.1016/S0045-7825(98)00016-4
C. Farhat and C. Degand, A three-dimensional torsional springs analogy method for unstructured dynamic meshes, Computer and Structures, vol.80, pp.305-316, 2002.
L. Fezoui and B. Stoufflet, A class of implicit upwind schemes for Euler simulations with unstructured meshes, Journal of Computational Physics, vol.84, issue.1, pp.174-206, 1989.
DOI : 10.1016/0021-9991(89)90187-3
URL : https://hal.archives-ouvertes.fr/inria-00076037
C. Fisher and A. Arena, On the Transpiration Method for Efficient Aeroelastic Analysis Using an Euler Solver, AIAA 96-3436, 1996.
J. Hadamard, Leon sur le calcul des variations, 1910.
E. Haug and J. Céa, Optimization of distributed parameter structures, 1981.
A. Iollo, S. Lanteri, and J. Désidéri, Stability Properties of POD-Galerkin Approximations for the Compressible Navier-Stokes Equations, Theoretical and Computational Fluid Dynamics, vol.13, issue.6, 1998.
DOI : 10.1007/s001620050119
URL : https://hal.archives-ouvertes.fr/inria-00073091
A. Jameson, Optimal Shape Design for Aerodynamics, in Optimum Design methods for Aerodynamics, AGARD Report 803, J. Periaux, Special Course Director at the VKI, pp.25-29, 1994.
A. Jameson, Optimum Aerodynamic Design via Boundary Control, AGARD Report, vol.803, 1994.
M. Karakis and J. Désidéri, Model Reduction and Adaption of Optimum-shape design in aerodynamics by Neural Networks, 2002.
H. Kuiper, A. J. Van-der-wees, C. F. Hendriks, and T. E. Labrujere, Application of genetic algorithms to the design of airfoil pressure distribution
T. Labrujere, Residual-Correction Type and Related Computational Methods for Aerodynamics , AGARD Report 803, J. Periaux, Special Course Director at the VKI, pp.25-29, 1994.
J. Lagarias, J. Reeds, and M. Wright, Convergence Properties of the Nelder--Mead Simplex Method in Low Dimensions, SIAM Journal on Optimization, vol.9, issue.1, pp.112-147, 1998.
DOI : 10.1137/S1052623496303470
H. Lamousin and W. Waggenspack, NURBS-based free-form deformations, IEEE Computer Graphics and Applications, vol.14, issue.6, pp.1-9, 1994.
DOI : 10.1109/38.329096
R. Lewis, V. Torczon, and M. Trosset, Direct search methods: then and now, Journal of Computational and Applied Mathematics, vol.124, issue.1-2, 2000.
DOI : 10.1016/S0377-0427(00)00423-4
M. J. Lighthill, A new method of two-dimensional aerodynamics design, R&M1111, Aeronautical Research Council, 1945.
M. J. Lighthill, On displacement thickness, Journal of Fluid Mechanics, vol.none, issue.04, pp.383-392, 1958.
DOI : 10.1017/S0022112058000525
J. L. Lions, Optimal control of system governed by PDEs, 1971.
N. Marco and A. Dervieux, Multilevel parametrization for aerodynamical optimization of 3D shapes, Finite Elements in Analysis and Design, vol.26, issue.4, 1996.
DOI : 10.1016/S0168-874X(96)00082-0
URL : https://hal.archives-ouvertes.fr/inria-00073750
N. Marco and J. A. Désidéri, Numerical solution of optimization test-case by Genetic Algorithms, INRIA Research Report, issue.3622, 1999.
N. Marco, J. A. Désidéri, and S. Lanteri, Multi-Objective Optimization in CFD by Genetic Algorithms, INRIA Research Report, issue.3686, 1999.
URL : https://hal.archives-ouvertes.fr/inria-00072983
N. Marco and S. Lanteri, A two-level parallelization strategy for Genetic Algorithms applied to optimum shape design, Parallel Computing, vol.26, issue.4, 1998.
DOI : 10.1016/S0167-8191(99)00116-7
URL : https://hal.archives-ouvertes.fr/inria-00073227
A. Marocco, Simulations Numériques dans la Fabrication des CircuitsàCircuitsà Semiconducteurs
B. Mohammadi and O. Pironneau, Applied Shape Optimization for Fluids, 2001.
DOI : 10.1093/acprof:oso/9780199546909.001.0001
URL : https://hal.archives-ouvertes.fr/hal-00385714
H. Mühlenbein, D. Schomisch, and J. Bord, The parallel genetic algorithm as function optimizer, Parallel Computing, vol.17, issue.6-7, pp.619-632, 1991.
DOI : 10.1016/S0167-8191(05)80052-3
J. Nelder and R. Mead, A Simplex Method for Function Minimization, The Computer Journal, vol.7, issue.4, pp.308-313, 1965.
DOI : 10.1093/comjnl/7.4.308
S. Obayashi and A. Oyama, Three dimensional aerodynamic optimization with genetic algorithms Third ECCOMAS Computational Fluid Dynamics Conference and Second EC- COMAS Conference on Numerical Methods in Engineering, volume Computational Fluid Dynamics '96, pp.420-424, 1996.
L. Oulladji, A. Janka, J. Désidéri, and A. Dervieux, Optimisation aérodynamique par algorithmes génétiques hybrides: applicationàapplicationà la réduction d'un critère de bang sonique, 2003.
J. Périaux, M. Sefrioui, B. Stoufflet, B. Mantel, and E. Laporte, Robust genetic algorithms for optimization problems in aerodynamic design, Genetic algorithms in engineering and computer science, pp.397-415, 1995.
O. Pironneau, Optimal shape design for elliptic systems, 1984.
M. Powell, Direct search algorithms for optimization calculations, Acta Numerica, vol.8, pp.287-336, 1998.
DOI : 10.1007/BF00933295
D. Quagliarella, Genetic algorithms applications in computational fluid dynamics, Genetic algorithms in engineering and computer science, pp.417-442, 1995.
P. Raj and B. Harris, Using Surface Traspiration with an Euler Method for Cost-effective Aerodynamic Analysis, AIAA 93-3506, 1993.
P. Roe, Approximate Riemann solvers, parameter vectors, and difference schemes, Journal of Computational Physics, vol.43, issue.2, pp.357-371, 1981.
DOI : 10.1016/0021-9991(81)90128-5
J. Samareh, A survey of shape parameterization techniques, CEAS AIAA ICASE NASA Langley International Forum on Aeroelasticity and Structural Dynamics, 1999.
T. Sederberg and S. Parry, Free-form deformation of solid geometric models, ACM SIGGRAPH Computer Graphics, vol.20, issue.4, pp.151-160, 1986.
DOI : 10.1145/15886.15903
W. Spendley, G. Hext, and F. Himsworth, Sequential Application of Simplex Designs in Optimisation and Evolutionary Operation, Technometrics, vol.39, issue.4, pp.441-461, 1962.
DOI : 10.1214/aoms/1177707047
J. Thompson, Z. Warsi, and C. Mastin, Numerical Grid Generation, 1985.
A. Törn and A. Zilinskas, Global Optimization, Lecture Notes in Computer Science, vol.350, issue.350, 1989.
DOI : 10.1007/3-540-50871-6
E. Toro, Riemann Solvers and Numerical Methods for Fluid Dynamics, 1997.
B. Van-leer, Towards the Ultimate Conservative Difference Scheme, Journal of Computational Physics, vol.135, issue.2, pp.361-370, 1979.
DOI : 10.1006/jcph.1997.5704
. Unité-de-recherche-inria-sophia and . Antipolis, 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex (France) Unité de recherche INRIA Lorraine : LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-l` es-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint, Ismier (France) Unité de recherche INRIA Rocquencourt : Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex, 2004.
I. Editeur and . De-voluceau-rocquencourt, BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399
