Abstract : We present a definition of analogy on sequences which is based on two principles : the definition of an analogy between the letters of an alphabet and the use of the edit distance between sequences. Our definition generalizes the algorithm given by Lepage and is compatible with another definition of analogy in sequences given by Yvon.
