Anisotropic Polygonal Remeshing, ACM SIGGRAPH Conference Proceedings, 2003. ,
DOI : 10.1145/882262.882296
URL : https://hal.archives-ouvertes.fr/inria-00071778
Progressive Encoding for Lossless Transmission of 3D Meshes, ACM SIGGRAPH Conference Proceedings, pp.198-205, 2001. ,
Valence-Driven Connectivity Encoding of 3D Meshes, Eurographics Conference Proceedings, pp.480-489, 2001. ,
SwingWrapper, ACM Transactions on Graphics, vol.22, issue.4, 2003. ,
DOI : 10.1145/944020.944022
On the Optimality of the Laplacian Spectral Basis for Mesh Geometry Coding, 2003. ,
Universal Rendering Sequences for Transparent Vertex Caching of Progressive Meshes, Computer Graphics Forum, vol.5, issue.2, pp.137-148, 2002. ,
DOI : 10.1109/83.499920
Compact encodings of planar graphs via canonical orderings and multiple parentheses, ICALP: Annual International Colloquium on Automata, Languages and Programming, pp.118-129, 1998. ,
DOI : 10.1007/BFb0055046
Progressive Compression of Arbitrary Triangular Meshes, IEEE Visualization Conference Proceedings, pp.67-72, 1999. ,
Geometry Compression, ACM SIGGRAPH Conference Proceedings, pp.13-20, 1995. ,
Geometric compression for interactive transmission, Proceedings Visualization 2000. VIS 2000 (Cat. No.00CH37145), pp.319-326, 2000. ,
DOI : 10.1109/VISUAL.2000.885711
URL : https://hal.archives-ouvertes.fr/hal-01179425
Progressive Lossless Compression of Arbitrary Simplicial Complexes, ACM SIG- GRAPH Conference Proceedings, pp.372-379, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00167216
Geometry Images, ACM SIGGRAPH Conference Proceedings, pp.355-361, 2002. ,
DOI : 10.1145/566654.566589
Simplification and Compression of 3D Meshes, Tutorials on Multiresolution in Geometric Modelling (Munich Summer School Lecture Notes), 2002. ,
DOI : 10.1007/978-3-662-04388-2_12
On the Optimality of Valence-Based Connectivity Coding, Computer Graphics Forum, vol.22, issue.1, pp.99-102, 2003. ,
New Bounds on the Encoding of Planar Triangulations, 2000. ,
Normal meshes, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, pp.95-102, 2000. ,
DOI : 10.1145/344779.344831
Harmonic Analysis, 1991. ,
DOI : 10.1007/978-1-4615-7181-0
Compressing large polygonal models, Proceedings Visualization, 2001. VIS '01., pp.357-362, 2001. ,
DOI : 10.1109/VISUAL.2001.964532
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.7096
Progressive meshes, ACM SIGGRAPH Conference Proceedings, pp.99-108, 1996. ,
Compressing Hexahedral Volume Meshes, Pacific Graphics Conference Proceedings, pp.284-293, 2002. ,
Compressing Polygon Mesh Geometry with Parallelogram Prediction, IEEE Visualization Conference Proceedings, pp.141-146, 2002. ,
A Benchmark Coder for Polygon Mesh Compression, 2002. ,
Out-of-Core Compression for Gigantic Polygon Meshes, SIGGRAPH conference proceedings, 2003. ,
Mesh Collapse Compression, Proceedings of SIB- GRAPI'99, pp.27-28, 1999. ,
Face Fixer: Compressing Polygon Meshes With Properties, ACM SIGGRAPH Conference Proceedings, pp.263-270, 2000. ,
Spirale Reversi: Reverse Decoding of the Edgebreaker Encoding, Proceedings of 12th Canadian Conference on Computational Geometry, pp.247-256, 2000. ,
Binary compression rates for ASCII formats, Proceeding of the eighth international conference on 3D web technology , Web3D '03, pp.173-178, 2003. ,
DOI : 10.1145/636593.636619
Compressing Polygon Mesh Connectivity with Degree Duality Prediction, Graphics Interface Conference Proc, pp.161-170, 2002. ,
Near-Optimal Connectivity Encoding of 2-Manifold Polygon Meshes, Graphical Models, vol.64, issue.3-4, 2002. ,
DOI : 10.1006/gmod.2002.0575
URL : https://hal.archives-ouvertes.fr/inria-00072013
Efficient compression and rendering of multi-resolution meshes, IEEE Visualization, 2002. VIS 2002., 2002. ,
DOI : 10.1109/VISUAL.2002.1183794
Spectral compression of mesh geometry, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, pp.279-286, 2000. ,
DOI : 10.1145/344779.344924
Efficient coding of non-triangular mesh connectivity, Proceedings the Eighth Pacific Conference on Computer Graphics and Applications, pp.263-275, 2001. ,
DOI : 10.1109/PCCGA.2000.883946
Optimized compression of triangle mesh geometry using prediction trees, Proceedings. First International Symposium on 3D Data Processing Visualization and Transmission, pp.602-608, 2002. ,
DOI : 10.1109/TDPVT.2002.1024124
Compression of Normal Meshes, Geometric Modeling for Scientific Visualization, 2003. ,
DOI : 10.1007/978-3-662-07443-5_12
Globally Smooth Parameterizations with Low Distortion, 2003. ,
DOI : 10.1145/882262.882275
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.654
Exhaustive Generation of The Art of Computer Programming, in preparation, available electronically, 2003. ,
Guaranteed 3.67V bit Encoding of Planar Triangle Graphs, 11th Canadian Conference on Computational Geometry, pp.146-149, 1999. ,
Compression for Irregular Quadrilateral Meshes, 1999. ,
Short encodings of planar graphs and maps, Discrete Applied Mathematics, vol.58, issue.3, pp.239-252, 1995. ,
DOI : 10.1016/0166-218X(93)E0150-W
Angle-Analyzer: A Triangle-Quad Mesh Codec, Eurographics Conference Proceedings, pp.383-392, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00072001
Vertex Data Compression For Triangular Meshes, Proceedings of Pacific Graphics, pp.225-234, 2000. ,
The Digital Michelangelo Project, ACM SIGGRAPH Conference Proceedings, pp.131-144, 2000. ,
3D mesh wavelet coding using efficient model-based bit allocation, Proceedings. First International Symposium on 3D Data Processing Visualization and Transmission, pp.391-394, 2002. ,
DOI : 10.1109/TDPVT.2002.1024089
URL : https://hal.archives-ouvertes.fr/hal-00369540
Compressed progressive meshes, IEEE Transactions on Visualization and Computer Graphics, vol.6, issue.1, pp.79-93, 2000. ,
DOI : 10.1109/2945.841122
URL : https://smartech.gatech.edu/bitstream/1853/3372/1/99-05.pdf
Optimal Coding and Sampling of Triangulations, 30th international colloquium on automata, languages and programming (ICALP'03), 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00159287
Edgebreaker : Connectivity Compression for Triangle Meshes, IEEE Transactions on Visualization and Computer Graphics, 1999. ,
Compression of Large 3D Engineering Models using Automatic Discovery of Repeating Geometric Features, proceedings of 6th International Fall Workshop on Vision, Modeling and Visualization, 2001. ,
High-Pass Quantization for Mesh Encoding, Proceedings of Eurographics Symposium on Geometry Processing, 2003. ,
Explicit Surface Remeshing, Proceedings of Eurographics Symposium on Geometry Processing, 2003. ,
Signal-Specialized Parametrization, Eurographics Workshop on Rendering, 2002. ,
Embedded Image Coding Using Zerotrees of Wavelet Coefficients, IEEE Transactions on Signal Processing, vol.41, issue.12, pp.3445-3462, 1993. ,
An Edgebreaker-based efficient compression scheme for regular meshes, Computational Geometry, vol.20, issue.1-2, pp.53-68, 2001. ,
DOI : 10.1016/S0925-7721(01)00035-9
Piecewise Regular Meshes: Construction and Compression, Graphical Models, vol.64, issue.3-4, 2003. ,
DOI : 10.1006/gmod.2002.0577
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.16.4062
Multi-Chart Geometry Images, Proceedings of Eurographics Symposium on Geometry Processing, 2003. ,
Geometry coding and VRML, Proceedings of the IEEE, pp.1228-1243, 1998. ,
DOI : 10.1109/5.687837
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.36.161
Succinct Representations of Graphs, Discrete Applied Mathematics, vol.8, pp.289-294, 1984. ,
A Census of Planar Maps, Canadian Journal of Mathematics, vol.15, pp.249-271, 1963. ,
route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, 2004. ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
