Kerrighed: A SSI Cluster OS Running OpenMP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Writing parallel programs for clusters of workstations is still a challenging task. In this paper, we present Kerrighed, a Single System Image (SSI) operating system giving the illusion of an SMP machine, and providing the standard posix thread interface to developers. It is therefore possible to use Kerrighed to run OpenMP programs compiled for SMP-machines using the posix thread interface. In this paper, we explain how we managed to achieve that goal, and present the benefits of providing OpenMP support through the SSI approach as opposed to a dedicated run-time environment.
Mots clés
Autre [cs.OH]
RR-4947.pdf (211.02 Ko) Télécharger le fichier
inria-00071632 , version 1 (23-05-2006)
  • HAL Id : inria-00071632 , version 1
David Margery, Geoffroy Vallée, Renaud Lottiaux, Christine Morin, Jean-Yves Berthou. Kerrighed: A SSI Cluster OS Running OpenMP. [Research Report] RR-4947, INRIA. 2003. ⟨inria-00071632⟩
294 Consultations
145 Téléchargements
