Global visualization of experiments in ad hoc networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Quang Vo
  • Fonction : Auteur
Isabelle Guérin Lassous
The real experiments in ad hoc networks study metrics that can be obtained with local monitoring on the machines. No global and full visualization of the experiments is proposed. However such a visualization can be very useful and can help in a sharp evaluation of the tested protocols. Setting this type of visualization requires a synchronization of the events performed during the experiment. In this paper, we propose a synchronization method that enables the setting up of a global visualization of experiments in ad hoc networks.
Autre [cs.OH]
RR-4933.pdf (1.28 Mo) Télécharger le fichier
inria-00071646 , version 1 (23-05-2006)
  • HAL Id : inria-00071646 , version 1
Dominique Dhoutaut, Quang Vo, Isabelle Guérin Lassous. Global visualization of experiments in ad hoc networks. RR-4933, INRIA. 2003. ⟨inria-00071646⟩
160 Consultations
143 Téléchargements
