3D Maxwell's equations and orthogonal nonconforming meshes: a hp-type Discontinuous Galerkin method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We present a Discontinuous Galerkin scheme to solve the time-domain Maxwell's equations on conforming or nonconforming orthogonal grids. The method relies on a set of local basis functions whose degree may vary at subgrid interfaces. We also choose a centered mean approximation for the surface integrals and a second-order leap-frog scheme for advancing in time. We prove that the resulting scheme is stable and that it conserves a discrete analog of the electromagnetic energy. We also analyse the dispersion error in the uniform mesh case.
RR-4912.pdf (768.6 Ko) Télécharger le fichier
inria-00071668 , version 1 (23-05-2006)
  • HAL Id : inria-00071668 , version 1
Nicolas Canouet, Loula Fatima Fezoui, Serge Piperno. 3D Maxwell's equations and orthogonal nonconforming meshes: a hp-type Discontinuous Galerkin method. [Research Report] RR-4912, INRIA. 2003. ⟨inria-00071668⟩
75 Consultations
222 Téléchargements
