N. Amenta and M. Bern, Surface Reconstruction by Voronoi Filtering, Discrete & Computational Geometry, vol.22, issue.4, pp.481-504, 1999.
DOI : 10.1007/PL00009475
V. Borrelli, F. Cazals, and J. Morvan, On the angular defect of triangulations and the pointwise approximation of curvatures, Curves and Surfaces, 2002.
DOI : 10.1016/S0167-8396(03)00077-3
URL : https://hal.archives-ouvertes.fr/inria-00071995
]. M. Ber87 and . Berger, Geometry (vols. 1-2), 1987.
I. Boissonnat and J. Flototto, A local coordinate system on a surface, Proceedings of the seventh ACM symposium on Solid modeling and applications , SMA '02, 2002.
DOI : 10.1145/566282.566302
P. [. Bruce and . Giblin, Curves and singularities, 1992.
DOI : 10.1017/CBO9781139172615
]. C. Coa66 and . Coatmelec, Approximation et interpolation des fonctions differentielles de plusieurs variables, Ann. Sci. Ecole Norm. Sup, vol.83, 1966.
J. [. Cohen-steiner and . Morvan, Restricted delaunay triangulations and normal cycle, Proceedings of the nineteenth conference on Computational geometry , SCG '03, 2003.
DOI : 10.1145/777792.777839
A. [. Csàkàny and . Wallace, Computation of local differential parameters on irregular meshes, Mathematics of Surfaces Differential Geometry of Curves and Surfaces, 1976.
E. [. Funke and . Ramos, Smooth-surface reconstruction in near-linear time, ACM SODA'02, 2002.
T. [. Gasca and . Sauer, Polynomial interpolation in several variables Advances in Comp, Math, vol.12, issue.4, 2000.
]. N. Hig96 and . Higham, Accuracy and Stability of Numerical Algorithms, 1996.
]. M. Las99 and . Lassak, Parallelotopes of maximum volumes in a simplex, Disc. Comp. Geometry, 21, 1999.
K. [. Lancaster and . Salkauskas, Curve and surface fitting: an introduction. Academic, 1986.
[. Morvan and B. Thibert, Smooth surface and triangular mesh, Proceedings of the seventh ACM symposium on Solid modeling and applications , SMA '02, 2001.
DOI : 10.1145/566282.566306
]. D. Mw00a, D. Meek, and . Walton, On surface normal and Gaussian curvature approximations given data sampled from a smooth surface, Computer-Aided Geometric Design, vol.17, pp.521-543, 2000.
]. D. Mw00b, D. J. Meek, and . Walton, On surface normal and gaussian curvature approximations given data sampled from a smooth surface, Computer Aided Geometric design, 2000.
]. S. Pet01 and . Petitjean, A survey of methods for recovering quadrics in triangle meshes, ACM Computing Surveys, vol.34, issue.2, 2001.
]. I. Por01 and . Porteous, Geometric Differentiation, 2001.
M. [. Polthier and . Schmies, Straightest geodesics on polyhedral surfaces, ACM SIGGRAPH 2006 Courses on , SIGGRAPH '06, 1998.
DOI : 10.1145/1185657.1185664
]. T. Sau95 and . Sauer, Computational aspects of multivariate polynomial interpolation Advances in Comp, Math, vol.3, issue.3, 1995.
J. R. Shewchuk, What is a good linear element? interpolation, conditioning, and quality measures, 11th International Meshing Roundtable, 2002.
]. M. Spi99 and . Spivak, A comprehensie introduction to Differential Geometry (Third Ed.). Publish or Perish, 1999.
Y. [. Sauer and . Xu, On multivariate Lagrange interpolation, Mathematics of Computation, vol.64, issue.211, 1995.
DOI : 10.1090/S0025-5718-1995-1297477-5
S. [. Sander and . Zucker, Inferring surface trace and differential structure from 3-D images, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.12, issue.9, pp.833-854, 1990.
DOI : 10.1109/34.57680
URL : https://hal.archives-ouvertes.fr/inria-00075442
]. G. Tau95 and . Taubin, Estimating the tensor of curvature of a surface from a polyhedral approximation, Fifth International Conference on Computer Vision, 1995.
A. [. Watanabe and . Belyaev, Detection of Salient Curvature Features on Polygonal Surfaces, Eurographics route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex, 2001.
DOI : 10.1111/1467-8659.00531
I. Unité-de-recherche and . Lorraine, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex
I. De-voluceau-rocquencourt, BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399
