On the controllability of linear juggling mechanical systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
This paper deals with the controllability of a class of nonsmooth complementa- rity mechanical systems. Due to their particular structure they can be decomposed into an "object" and a "robot", consequently they are named juggling systems. It is shown that the accessibility of the "object" can be characterized by nonlinear constrained equations, or generalized equations. Examples are presented, including a simple model of backlash. The main focus of the work is about linear jugglers, but extensions towards more complicated models are considered.
RR-4772.pdf (366.25 Ko) Télécharger le fichier
inria-00071814 , version 1 (23-05-2006)
  • HAL Id : inria-00071814 , version 1
Bernard Brogliato, Mongi Mabrouk, Arturo Zavala-Rio. On the controllability of linear juggling mechanical systems. [Research Report] RR-4772, INRIA. 2003. ⟨inria-00071814⟩
167 Consultations
305 Téléchargements
