Estimateur d'erreur géométrique et métriques anisotropes pour l'adaptation de maillages. Partie II : applications, 2003. ,
Directional adaptive surface triangulation, Computer Aided Geometric Design, vol.16, issue.2, pp.107-126, 1999. ,
DOI : 10.1016/S0167-8396(98)00040-5
A-posteriori error estimates for the finite element method, International Journal for Numerical Methods in Engineering, vol.15, issue.10, pp.1597-1615, 1978. ,
DOI : 10.1002/nme.1620121010
Mesh Smoothing Using A Posteriori Error Estimates, SIAM Journal on Numerical Analysis, vol.34, issue.3, pp.979-997, 1997. ,
DOI : 10.1137/S0036142994265292
SOLUTION-BASED MESH QUALITY INDICATORS FOR TRIANGULAR AND TETRAHEDRAL MESHES, Proc. 6th International Meshing Roundtable, Sandia Lab, pp.427-436, 1997. ,
DOI : 10.1142/S021819590000019X
Estimateurs d'erreur géométriques et adaptation de maillage, dans Maillage et adaptation, Série Mécanique et Ingénierie des Matériaux, Méthodes Numériques, 2001. ,
Anisotropic unstructured mesh adaption for flow simulations, International Journal for Numerical Methods in Fluids, vol.59, issue.4, pp.475-491, 1997. ,
DOI : 10.1002/(SICI)1097-0363(19970830)25:4<475::AID-FLD575>3.0.CO;2-6
Introduction à l'analyse numérique matricielle et à l'optimisation, 1982. ,
Anisotropic mesh adaptation - Towards a solver and user independent CFD, 35th Aerospace Sciences Meeting and Exhibit, pp.97-0861, 1997. ,
DOI : 10.2514/6.1997-861
Estimation a posteriori et adaptation de maillages, Revue Européenne des Eléments Finis, 2000. ,
Maillages : applications aux éléments finis, Hermès Science, 1999. ,
On the Maximum Angle Condition for Linear Tetrahedral Elements, SIAM Journal on Numerical Analysis, vol.29, issue.2, pp.513-520, 1992. ,
DOI : 10.1137/0729031
Toward anisotropic mesh construction and error estimation in the finite element method, Numerical Methods for Partial Differential Equations, vol.9, issue.5, 2000. ,
DOI : 10.1002/num.10023
Basic error estimates for elliptic problems, in Handbook of numerical analysis, 1991. ,
Adaptiveh-refinement on 3D unstructured grids for transient problems, International Journal for Numerical Methods in Fluids, vol.1, issue.12, pp.1407-1419, 1992. ,
DOI : 10.1002/fld.1650141204
Function approximation on triangular grids: some numerical results using adaptive techniques, Applied Numerical Mathematics, vol.32, issue.4, pp.389-399, 2000. ,
DOI : 10.1016/S0168-9274(99)00059-8
3D Mesh adaptation by metric control for CFD, Revue Européene des Éléments Finis, pp.439-449, 2000. ,
Tetrahedral mesh optimisation and adaptivity for steady-state and transient finite element calculations, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.29-30, pp.3771-3796, 2001. ,
DOI : 10.1016/S0045-7825(00)00294-2
A 3D unstructured mesh adaptation algorithm for time-dependent shock-dominated problems, Int. J. Numer. Meth. Fluids, vol.25, pp.81-104, 1997. ,
Génération de maillages anisotropes adaptés -Application à la capture de couches limites, 1990. ,
A Review of A Posteriori Error Estimation and Adaptive Mesh- Refinement Techniques, 1996. ,
